Question about Sub-Zero 680 / F
Model 680-1. freezer is icing up especially around the icemaker. Seems to try to defrost but drips down to the lower section. 2. Icemaker controls on the door are constantly clicking.
  • 1 more comment
  • dan6800 May 23, 2011
    The unit is a model 42" 680 approx 10 years old.
    Thank you rick I will try that. I should continuity through it right???
    Thank you Rick. the main freezing is at the icemaker. The whole thing was encased in ice.
  • 1,998 Answers
If your freezer is iceing up this is due to a defrost issue that comes from either the defrost thermostat, the defrost heater, or the defrost timer or on some adaptive control board. you can perform continuity tests with a multimeter on the thermostat and the heater using a multimeter and the defrost timer i think in the 680 is found in the same spot as the 550 where the compressor is next to the condensor coil if you dont see a defrost timer then you would have an adaptive control board on 80 percent of the defrost issues are due to a bad defrost thermostat if you have any questions message me back Thanks Rick
Posted on May 23, 2011
  • 2 more comments
  • Rick Ead
    Rick Ead May 23, 2011
    you can also read more on why this happens by clicking this link http://www.applianceoutletservice.com/ap... Once again if you have any further questions message me back I await your reply Thanks again Rick
  • Rick Ead
    10 years old then you would have a defrost timer like the 550 model and not an adaptive control board first thing to do would be to goto your evaporator coil on one of the copper lines you will see a small round disc with two wires going to it this would be the defrost thermostat and test this for continuity Thanks Rick
  • Rick Ead
    each piece that is good would show continuity through it correct so you would first remove the defrost thermostat i know on subzero there is a plug clip in and then you would test the defrost thermostat Not always on a subzero is it only one problem either recently while i was repairing a similar issue in a subzero 550 xl i had no continuity to the defrost thermostat in which i replaced the defrost thermostat four weeks later i get a call back on the job for I stopped diagnoseing when the thermostat showed no continuity it was in fact also the defrost timer that had went as well so im also includeing a video on how to test the defrost timer as well tricky lil buggers subzero are on most units if it shows one fault you wouldnt get another but on subzero you might as well test so you dont end up with the same issue that I had heres the video http://www.youtube.com/watch?v=tPpLl2d00...
    i await your reply if you have any further questions and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
  • Rick Ead
    do you have a leak where the water comes in from the back of the machine if so then you would replace the water inlet valve located at the rear of the machine a constant drip would mean you would have to replace the valve Thanks I await your reply Rick
  • 6,993 Answers
unfortunately, there is no service manual for this model of Samsung side by side refrigerator. But I think I can help you out....
Do you notice frost accumulation in the back wall inside the freezer area?
If you do, the freezer evaporator could have frosted up or the defrosting cycle is not functioning in the freezer.
What I can suggest is to defrost the unit manually by unplugging the unit for a whole day. Remove and transfer all the food to prevent spoilage to another unit if you have one.
Then if all ice has thawed up, plug it back and start from scratch.
Observe the unit if it will now cool back normally both fridge and freezer.
Keep me posted.
Regards.
Water & ice in bottom of freezer
Most likely cause is a blocked defrost drain line. The freezer has a defrost cycle which turns on a heating element below the evaporator to clear any built up frost or ice. This defrosted water should then drain through a plastic line to below the unit. Check for drained water in the drip pan or plastic moulded container over the compressor. If it is completely dry then follow the blocked drain line, clear it. If further assistance is required please provide details of What brand and Model your unit is? Hope this helps.
Feb 14, 2014 | GE Refrigerators
Water dripping from top rear center of refer section. icing up and dripping, about a cup a day. seems unrelated to icemaker operations or humidity. What direction do numbers mean when setting temp for...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | KitchenAid Refrigerators
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
Have a side by side kenmore ref. and the ice machine is not making any ice. The ice maker switch is on and I am getting water. Model on my manual reads 106.58916801. any suggestions.
Hi and welcome to FixYa. I am Kelly. Having determined your icemake is PN W10190960 , here is a link that will help you test your icemaker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The steps are pretty straight forward and will isolate exactly which component of the icemaker / system has failed.
I would like to note that these icemakers are very reliable. They do occasionally fail but most of the time the problem is the freezer is not defrosting properly so the airflow through the freezer is blocked by ice build-up in the evaporator coils due to that defrosting problem.
Your unit has an electronic control board that controls the defrost circuitry.
If you check out the icemaker assy per the first link and still have the problem I would recommend doing a manual defrosting by unplugging the unit. Then remove the contents of the freezer section and place a fan blowing into the freezer section for just over 2 hours. This makes a water mess so be prepaired.
After the manual defrosting cycle restart the unit and reload the freezer contents. After about 12 hours check the icemaker to see if it made any ice at that point. If this solves your icemaking problem it will only be temporary if you still have an automatic defrost cycle problem. Your unit should defrost at least 3 times in 24 hours.
Thanks for using FixYa.
Kelly
Apr 01, 2010 | Refrigerators
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
FRIGIDARE FRS26ZSEB: Freezer side, bottom collects ice and then leaks out the door.
If you get ice in the freezer, start checking if the evaporator fan and the defrost system is working.
Try doing a complete defrost, ofthen this can solve the problem.
Cause for ice in the fridge can be evaporator/defrost syste, bad gasket, faulty thermistor.
Sep 14, 2008 | Frigidaire Refrigerators
Amana ice-maker
Very curious. When you say the tube to the ice maker was disconnected I am unsure as to which tube you are refering to. However hopefully a few pointers might help a damsel. Most units have the water supply enter into the cabinet through a two way water solenoid valve (i.e. one for chilled water one for the ice maker). It then normally enters the top of the freezer section for the ice maker. It then drops down inside the freezer section to the icemaker module. Therefore the only control over the water for the icemaker is the solenoid valve which is controlled by the icemaker "module". A trick is to switch the control at the solenoid valve so that you can use the chilled water dispenser to check if the water valve for the icemaker is working. If it is then you probably have a problem with the icemaker module or the temperature in the freezer section (which you would probably have noticed if that was the case). If you have a problem with the module then you normally have to replace the module as they dont like supplying spares for modules.
Anyway hope this is of some help and good luck.
ps model is normally near the salad drawer or top of the fridge section dependent on brand.
Feb 08, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
GE TPX24BPBGBB fresh food section won't cool
Have you noticed any ice built up on the rear freezer wall? it is very likely that you have a defrost problem situation,IE: Heater,Defrost Thermostat,Defrost Timer any failure in these components will cause an icing problem and therefore you will not get sufficient air flow to the Food Compartment
Sep 20, 2007 | Refrigerators
Refrigerators Logo
110 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
