Question about Keurig B50 Coffee Maker
.B70 Coffee Maker - I
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
Keurig Coffee Maker Elite: Coffee is showering instead of streaming into my cup and is going onto my countertop. I cannot make a cup of coffee without this happening. Thanks for any help.
The bottom needle is plugged....Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
heatman101
Aug 05, 2011 | Keurig B60 Coffee Maker
Just bought the B70 coffee maker, ran water thru it initially as instructed. When put in the first k-cup it brewed but just before the water finished it spurted and spewed a couple of times...dropping...
Sorry to read about your problem, I hope this helps you out.
i think you had a bad k cup
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Keurig B70 Coffee Maker
Platinum B70 keurig coffee maker water heats up but won't allow the water to dispense into cup for coffee?tea
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Sep 15, 2010 | Keurig B100 Coffee Maker
Why would water spew out while using My kcup in the keurig?
The top gasket is not sealing on the endention of the my k cup. Open the handle look inside around the top needle and there will be a black gasket around it. Pull it down just a little so that it makes better contact with the My K Cup.
Mar 21, 2010 | Keurig Elite B40 Coffee Maker
Permanent Keurig filter leaks
Are you using the my k-cup with the Keurig pre-filled K-cups? If so it won't work. There must be a needle on the top and bottom of the K-cup for this machine to work. The My personal K-cup does not have a needle in the bottom. It's only to be used for filling with your own coffee.
Sep 17, 2009 | Keurig B70 Coffee Maker
Keurig B50 Coffee Maker Logo
137 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
