Question about HP Deskjet 5940 Photo InkJet Printer
Deskjet 1540 changes color from black to red
When printing the test page, the lines that say, "Additional files used by this driver:" print in black, the ninth line is half black and fading to red,
the tenth and following are all red. Can this be fixed or do I need a new printer?
    Problem Solver:
  • 10 Answers
There could be two reason for the issue. One if you refill cartridges then that could cause the problem. Second your cartridge might be running low. Please reply or let me know if this help. Change your cartridges.
Thanks
Posted on Aug 15, 2008
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Jul 13, 2009 | HP DeskJet 990cxi InkJet Printer
My HP deskjet D1560 won't print in color.
Do a test pattern to make sure printer is working. If all is fine try performing a reset of the electronics to factory defaults. Also re install the driver and check your settings.
Sep 17, 2017 | HP D1560 Deskjet Printer InkJet
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Jan 27, 2009 | HP DeskJet 940c InkJet Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
Printing only in color
hmm...maybe your print drivers went off line?
remove them, and go here for a fresh set
happens sometimes from power glitches
Mar 25, 2008 | HP DeskJet 6540 InkJet Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
HP DeskJet 1600cn doesn't print color
Hi Vern,
Check the print driver setting for an option that may be checked "print monochrome", remove this check mark.
Aug 11, 2017 | HP DeskJet 1600cn InkJet Printer
HP Deskjet 5940 Photo InkJet Printer Logo
354 people viewed this question
Ben Johnson
