Question about Toshiba Satellite A300-0CF035 Notebook
When i open the power, the system will ask you to press f2 for setup or f12 for ... then when i press any of them, the system will say, opening setup or opening multiple.. then nothing happens.
  • d_morandarte May 23, 2011
    @cyborjs
    yap, that is what i want to do, to reinstall the OS. But i cannot go to that step because when i press f2 or f12, it just display the message "opening setup..." then nothing happens. I cannot open the setup or the multiple boot menu. it just stops from there.
    Sergeant:
  • 167 Answers
The operating system is corrupted maybe some virus did it try to reinstall the OS
Posted on May 23, 2011
  • Emmanuel Borja May 24, 2011
    power off your pc try to pull out the battery of your motherboard it look like a dime then power on computer then power it off again then pull the plug then put the battery back and power on again then hit f12 or f2 to inter the bios setup
Bios setting probleme
you can not press the F12 or F2 Key at startup ....You need to hold the key down abd bios will open of boot order if F12 is pressed.
So hold the key down(F2,F12) then press the power key...keeping the F key pressed down.
Good Luck
Jun 19, 2013 | 10 10 Computer Network adapter Cable...
I need to restore my acer pew71 to factory settings but i only get as far as the acer start up screen. it has windows 7 on it. any suggestions?
omg....
this all not help me...
when i open my acer..
Press [F2] to Enter Setup does NOT Appear
i dont see press <Del> or <F10>... i only see <F2>... when i press its not open....
what can i do for this..
anyway to install this?
or i need download any boot?
Dec 27, 2012 | Computers & Internet
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Aug 26, 2011 | Toshiba Computers & Internet
Install to pc
Power on the computer and enter the BIOS menu. It will tell you which button to press to enter setup. Generally it will be F1, F2 F10 F12 or Del.
At this point you can insert your operating system disc.
In BIOS navigate the menus and look for Boot Order, or similar Make sure CD/DVD boots before anything else
Press whichever key the menu states to save and exit (Probably F10)
When the computer boots it should either start booting to the installation setup or ask you to press any key to enter installation. Do so and follow the prompts to install your operating system.
Post if you need more info.
Jul 12, 2011 | Computers & Internet
No operating system found
If the error message says "No operating system found" it is most likely a faulty disk controller or a faulty hard disk.
Reseat the hard disk, if this doesn't work you need to test the hard disk another way. Remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If this computer sees this as an external hard drive and you can open the folders and files then the hard disk is OK and the fault is the disk controller on the the 4115c laptop.
If the hard disk is not detected then the hard disk is faulty. You need to install a new hard disk, install Windows and the laptop's device drivers and programs to get a working laptop again.
Sep 11, 2009 | Computers & Internet
Acer extensa 5220. how ;open bios? f2 or f10 or f12 or what?
Try On bootup you should either Press 'DEL' or 'F1' or 'F2' to enter the BIOS
Jun 14, 2009 | Computers & Internet
Laptop A3 not booting up
Sounds like your hard drive is not booting and that your keyboard isn't responding to your pressing F2 and F12. If you can locate a USB external keyboard or if you have a round PS2 port for an external keyboard/mouse - plug into the laptop with that then press F12 while the computer is booting, press it a few times to be sure you get it in the buffer - then the boot manager should show up. If it does, choose to boot the Hard Drive if available - same with pressing F2 - Setup or Bios CMOS Settings should be displayed, here you can try to boot from the Hard Drive or Check to see if the hard drive is being recognized or not.
You may need a new keyboard if your laptop keyboard doesn't get you into either menu, and to either make sure your hard drive is responding and can be set to be the default boot device.
Mar 23, 2009 | Toshiba Tecra A3 Notebook
Unable to open BIOS Setup
Are you trying to change the boot up drives so that the CD boots up first so you can do a repair or reinstall Windows?
Try F2
You can select from a list of bootable devices by pressing F12
Dec 31, 2008 | Lenovo 3000 C200 Notebook
Toshiba Satellite A300-0CF035 Notebook Logo
22 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
