Question about HP Photosmart Premium C309g multifunction InkJet Printer
All ink cartridges are full and still always says ink system failure
    Guru:
  • 731 Answers
Hi Debra,
Ink system failure is not related to the cartridge, it deal with the printer ink delivery mechanism hardware. It's an hardware issue.
Please CLICK HERE and you will find the steps to guide you in fixing this problem.
Regards
Riztech
Posted on May 23, 2011
.photosmart c6180 ink system has failed unable to copy recieve fax or printerror 0xc18a001
As always I start with the dreaded question. Did you use a refilled cartridge in your printer? If so, remove it and install a new HP cartridge. Recycled cartridges are famous for this type of failure. By the way the error code is a Windows error code. If you haven't found a solution to the " ink system failure " yet, it is quite easy to reset (using the buttons) on HP C7180. You can find the reset instructions on my website: http://www.inkbank.com.au/webcontent21.htm
Try this:
May 04, 2015 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0101 persists. Have tried solution given earlier for 0xc18a0001 without success. Ink system failure not resetting; all cartridges are full.
Its tricky mechanism, once printer detects ink system failed it cannot be resetted. Do this take out cartridges from printer., open right cover., find out logic card., remove cmos battery., wait for 5 minutes., refix batyery., power on the printer., follow the screen messges ... I hope it will solve the issue..
Sep 15, 2014 | HP Office Equipment & Supplies
Ink system failure
  • Please check the cartridges.Are they well installed?[Install them correctly].Still have ink?[replace if out of ink].
  • Also you can check the whether the cartridges pink/orange tape[when new] was fully removed for full cartridge connection.Here's how to:-
  1. With the printer on,raise the cartridges door open to access them[cartridges].
  2. Remove the cartridges from their slots by pressing the tab that is in front of the cartridges.
  3. Now check them.
Hope it helps.Thanks!
Oct 05, 2011 | HP Officejet 6500 Wireless All-in-One...
Printer is showing ink system failure. what does this mean? how can it be fixed?do we just need to replace all of the ink cartridges? help!
Ink system failure indicated that ink delivery mechanism of the printer is experiencing problem. We need to do below resets for this printer to fix this issue.
Solution 1:
  • Press the On button to turn of the printer.
  • Unplug the power cord from the back of the printer and from wall outlet or surge protector.
  • Removed all the ink cartridges
  • Wait for 2 minutes
  • Connect the power cord and turn the printer On.
  • Install the ink cartridges
(Please go to solution 2 if the problem is not resolved)
Solution 2:
  • Remove all the ink cartridges.
  • While the printer is ON, unplug the power cord from the back of the printer.
  • Press and hold OK and Cancel button, while holding these buttons connect the power cord.
  • Release the button after 20 seconds.
  • Turn on the printer if it goes off and install the cartridges.
Regards
Riztech
Mar 04, 2010 | HP Photosmart 3210 Printer
Hp photosmart c7250 ink system failure
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 03, 2010 | HP Photosmart C7250 All-In-One Thermal...
I have the ink system failure error and error Oxct18a0206 I was going to try and fix it and it somewhere it said that it could be because the ink cartridges are low. How do you see what level they are at...
Yes, The error is caused by air in the ink feed tubes which happens when the ink in the cartridges runs out or you use an improperly filled cartridge. We have a step by step repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
There is not any easy way to determine the level of ink in the cartridges but you will need to use full cartridges when you do the air purge procedure needed to clear the error.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Have a hp 3310 it says ink system failure error 0xc18a0106 it wont print,scan,copy and it does have enough ink. thank 4 ur help
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Feb 20, 2010 | HP Photosmart 3310 All-In-One InkJet...
Ink system failure
There are several causes for ink failures. Please provide a better description of the failure.
The two most common failures are:
1) Using third party ink cartridges or refilled ink cartridges.
2) Failing to remove the packing tape that covers the contacts on the cartridge.
Jan 26, 2010 | Office Equipment & Supplies
Ink system failure error Oxc18a0306
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart Premium C309g multifunction InkJet Printer Logo
367 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
