Question about Video Cameras
I am looking for the correct power supply for a Intellisense IV380-C24A CCTV Camera. The rear of the camera looks like this: http://dl.dropbox.com/u/1876455/DSC00635.JPG So it needs 24V AC. but I am unsure about using a power source with the wrong Amperage. Also I am right in thinking that the ground connection can be attached to any object that touches the ground? Any advice would be appreciated, Thanks!
SOURCE: re-attach power source
Okay I fixed my camcorder. I did a ggogle search and came across this solution which worked...I strongly suggest you do this. I whacked it two times on each side with the palm of my hand. IT WORKS NOW! I guess sony is aware of this malfunction and this is probably how they fix it....The error code is gone the tape plays. And it didn't cost me a penny.... Good luck and let me know if it worked for anybody else......
Posted on Jan 14, 2008
SOURCE: re-attach the power source flashing
I had the same problem. I took off the battery pack and wiped the it down with a kleenex as well as the socket in the camera where the battery pack connects to. This fixed the problem.
Posted on Mar 15, 2008
SOURCE: "Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Posted on Oct 26, 2008
SOURCE: i have a camera sony dcr-hc51e, (c:32:11 problem)
actually 32:11 is related to the casette compartment error.
reset the camcorder.
if the problem perist then you had to go to the service centre as mechnical section of the camcorder is not working properly and u cant align that your own.
thanx
jasdeep
Posted on Jun 30, 2009
old marine
  • 2128 Answers
SOURCE: FireWire for camcorder mini dv
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Posted on Aug 21, 2009
I have a wireless surveillance system, 4 chanel. came with 2 cameras. have purchased additional camera. How do I get the system to accept camera?
I am going to write a short discussion because I feel this subject is best handled by a person that knows what they are doing. There are plenty of Youtube videos that shows you how to install a CCTV system. As you didn't mention what type of CCTV camera it is, can this topic become very lengthy.
Please look at this tutorial on youtube,
The old systems is not difficult to do it yourself if your technical minded, although the newer systems will require some IT background. I recommend a certified installer to assist you, you can damage the camera if you don't know what your are doing.
Get the correct cabling and connectors.
The easiest are the pre-crimped cabling for DIY and it is plug and play. No setup is usually required for the CCTV recorder to work unless the recording on the CCTV was disabled. Any other setup will require special tools.
You get 2 kinds to wired CCTV camera systems.
The old tech is analogue with a thick data cable and set of wire for power.
The professional installed cabling will require a technical person to crimp the CCTV cable with a special BNC crimping tool. The
The old systems needs to have
The newer systems uses LAN cables.
The newer systems requires an IT/CCTV tech person to set it up.
Sep 19, 2017 | Came Home Security
Can i hook up a intellisense IV380 video camera in a motor vehicle
Yes, but unfortunately only in a Stanley Steamer
Apr 08, 2017 | Video Cameras
Cctv dvr beeping
Shut it down reboot it's saying that one of the cameras is not functioning correctly if this don't solve it then check all power supply's to each camera
Feb 06, 2014 | Swann Communications DVR4-Pro-Net...
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
Rear view camera instalation
Mount the camera on the back and the monitor in the front. Run the necessary wires and connect it to the power supply.
Feb 24, 2013 | Rear View Safety Rear View Night Vision...
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
Inop 14" B&W CCTV monitor
You are correct. The power supply (trace) is a very high voltage device. If it goes out, you will receive no power anywhere in the unit. It will most likely be cheaper just to replace the monitor.
Dec 05, 2008 | Home Security
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
