Question about Garden
My MAC 3227 trimmer will start an only run for a short time (less than a minute). It needs for the chock to be in the half chock position to start. If I move the chock to non-chock it stops. If I squeeze the throttle it stops.
  • 731 Answers
Remove the carburator.. It's plugged.
disassemble and soak the body in fresh gasoline for about 10 mins.
Blow out all the ports with small engine carb cleaner and reassemble.
Drain the gas tank , clean it and refill with fresh gas mixture
It doesn't take much to clog those little carbs
Posted on May 23, 2011
Fuel mixture for mac 3227 trimmer
mixture ratio for most trimmers and small engines will be 25 to.1 through to 50.to 1. It iiright when there is just a sight of blue smoke when operating
around 30 to 1 will be a good place to start
Apr 07, 2015 | Garden
Just starting to use this spring, and having fuel starvation issues. I ran it this winter a couple times and it ran properly.
add a little carb cleaner to the gas and try letting it run on half choke for a while longer .
Mar 28, 2015 | Garden
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Starting mac 3227 trimmer
As you have done most things, i would suggest you have a massive air leak, either through the cylinder or crankcase gasket, or through the crank seal, i think its time to pull the whole engine down and replace these items.
May 29, 2012 | Garden
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
Strimmer starts will run on half chock,but not with ckock off
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks Good Luck,
I hope this helped
Aug 10, 2010 | Craftsman 25cc Gas Line Trimmer
How ajust carburator on a McCulloch Mac 3227 gas trimmer
If the trimmer is made for US the carb is not to be adjusted.
Jun 08, 2010 | Garden
What does the symbols mean on the controls
the on off switch has a o and a I The o is off and the other is on
as for the other three you have a from right to left on the main body full chock the half chock the run prime it 7 times on the primer ball with the full choke on the pull crank cable 3 times then move choke to half choke then pull until it starts if after 10 pulls it doest start out back to full choke and sart again if and when it startes let it rund for about 15 secs on half choke then move to run If after all that and you have done it a few times and it still doesnt start get rid of it as it is a totally rubbish tool I know i had one for 6 m onths used iit 3 times then i bought a stihl.
May 30, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi trimmer quits running after I turn choke off and pull trigger to speed it up
run it with chock on half way it will start running better after a wile
Sep 20, 2009 | Garden
I have a Ryobi trimmer and when I start it will not stay on
Here was my solution:
I was having problems with my ryobi cs30 weedeater also. It would start up fine on full choke, but i could not give it more than half throttle or ever take the choke off or it would stall out. I replaced fuel mixture, spark plug, spark arrestor/exhaust, fuel lines, cleaned carb, and still nothing! I was considering getting a better machine. Then i decided to play with the carb adjustments.(on my cs-30, they are two screws on the carb that have a "L" and "H" next to them) I dont think you can get the specialty tool for adjusting the carb unless you are a repair tech, so i just took a Dremmel tool with the circular cut-off wheel to the head of the specialty screws and made them into "flat-head" screws so i could adjust them with a regular screwdriver (if you dont have a dremmel too, get one!) (As i was cutting into the head of the screws, i also cut into the casing protecting the head of the screws that was in the way, this does not cause any damage to the unit, that casing is only there to keep "un-certified" people from adjusting it for themselves.)
Now to the easy part: The "L" screw adjusts the idle fuel mixture and the "H" screw adjusts the full throttle fuel mixture. turning the screws clockwise make the machine run leaner (less fuel) and counter clockwise makes it run richer (more fuel).
-I started out by turning each screw 1/2 turn counter clockwise and started it up, then as it was idling, i started adjusting the "L" screw as i was moving the choke position to run, after a few full turns counter clockwise of the "L" screw, it was idling perfectly in the run position, then i did the same thing the the "H" screw while holding down the throttle and i got it to run perfectly in the run position. Now it is running way better than it ever has. I hope this helps everyone.
Good Luck!
Mar 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
