I would like to convert 1.3 mm/sec to mils - Computers & Internet
  • 394 Answers
Go to the site
http://www.cleavebooks.co.uk/scol/ccspeed.htm
and enter 1.3 inType in size . . . and select unit as mm/sec and press convert.
It will give you the values in different units.
Thanks for using FixYa.
Posted on May 23, 2011
I need to convert 5'4 into Centimeters?
Here is the math info, you do the math.
One mm is one "millimeter" or one one-thousandth of a meter (1 mm = 1/1000 m).
One cm is one "centimeter" or one one-hundredth of a meter (1 cm = 1/100 m).
Therefore, 1 cm = 10 mm. To convert mm to cm, divide the number of mm by 10 to get the number of cm
Jan 23, 2017 | Office Equipment & Supplies
Spark plug gap for 1997 C1500?
Spark plug gap can affect the life of the condenser if you have a points and condenser ignition. If your car has Capacitive Discharge (CD) ignition, the gap will be OK anywhere between 25 to 30 thou (28 mil is usually optimum). 28 thou on spark plugs is fine for points ignition as well.
If you have a metric feeler gauge, type in "conversion" on your web browser, you will find a number of programs that will convert anything to anything to convert thou (thousandths of an inch) to mm.
Jul 26, 2014 | 1997 Chevrolet C1500
Convert 182m to mm
1000 mm in 1 m so 182000 mm
May 27, 2014 | Garden
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Show the work on doing convert 15.9 mm to its equivalent in km
You have got to try to remember (or learn) the prefixes used in physical units. Milli means 1/1000 or 10^-3. Kilo means 1000, or 10^3. To convert from mm to meters you have to divide by 1000 because a mm is a 1000 time smaller than a millimeter and 1 mm is 0.001 m or 10^-3 m.
To go from 1 m to 1 kilometer you have to divide again by 1000. So 1 m=10^-3 km=1 km/1000
I leave it to you to figure out how to go from mm to km. It is not difficult and you have got to learn a bit by doing your homework.
Use these two equalities
1 mm = 0.001 m
1 m = 0.001 km
So 15.9 mm =
May 28, 2011 | Texas Instruments TI-83 Plus Calculator
I want to know which lens in better the 70-200mm vr ii or the 70-300mm. please let me know
Both have 70 mm as the widest angle of view, and up to 200 mm as telephoto, while one goes 50% further to 300 mm telephoto range. This means you can zoom in on objects further away than with the 200 mm lens. This is called the focal length of the lens.
The 200 mm offers VR II (second generation of Vibration Reduction) technology, which will allow shooting without a tripod in darker situations than without this technology. This can be a very handy feature if you are in low light situations and don't like to carry a tripod around.
Besides the focal length, a big part of a lens's cost and desirability is how "fast" it is. A lens that has an opening of "f2" is said to be "twice as fast" as one that is "f4". Another way to think of it is that it can allow twice the amount of light into the camera in the same amount of time that an f4 lens can. This means you can shoot in 1/60 sec at f2 as opposed to 1/30 sec at f4 to get the same amount of light in the image. If you don't have a tripod, and you're shooting at 70mm, 1/60 sec is the slowest you can shoot to get a non-blurred image (don't shoot slower than the inverse of the focal length: 70mm = 1/70 sec or 1/60 sec and when zoomed in 200 mm = 1/200 sec - or 1/250 on your camera) The more inexpensive wide angle zooms are often f4.5 - f5.6 and can run several or more hundred dollars. The f2 lenses cost several times more than the f4 - f5 counterparts. This is where the VR technology comes into play. This feature "freezes" the image to allow for an exposure that would be too blurry or otherwise not viewable. You can read a quick article about the differences between VR and VR II for Nikon lenses here. There are others to read, too - so read more than one for more than one opinion.
Another variable, is the coatings. Multi-coated lenses are generally more expensive than single or non coated lenses. Each coating reduces unwanted effects of stray light, etc. that can cause flares on images, etc. You can read more about coatings here.
There are other variables, but those are the main points. You'll have to weigh the differences between the lenses, your intended use for them and cost.
I hope this provided a good starting point for you and good luck!
Nov 18, 2010 | Nikon D90 Digital Camera with 18-105mm...
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
P1740 code came on for a 2001 dodge ram 1500 what does it mean?
This is the OD Solenoid. There is a TSB out that covers the 2000-2001 Ram truck.
EFFECTIVE DATE: Oct. 02, 2000
SUBJECT:
46RE Transmission MIL Due To DTC P1740 – TCC or OD Solenoid Performance
OVERVIEW:
This bulletin involves the replacement of the transmission pressure boost valve cover
plate.
MODELS:
2000 - 2001 (AB) Ram Van
2000 - 2001 (AN) Dakota
2000 - 2001 (BR/BE) Ram Truck
2000 - 2001 (DN) Durango
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 46RE
TRANSMISSION BUILT BEFORE AUGUST 01, 2000 (MDH 0801XX).
SYMPTOM/CONDITION:
The customer may complain of a Malfunction Indicator Lamp (MIL) illumination. Upon
further analysis, it is determined that the MIL is caused by Diagnostic Trouble Code (DTC)
P1740 - Torque Converter Clutch (TCC) or Overdrive Solenoid Performance. Other than
the MIL, the customer may not notice any other condition with the transmission.
This condition may be caused by an intermittent and momentary TCC disengagement
condition. The transmission valve body pressure boost valve cover plate has been revised
with a larger size orifice hole to address this condition.
DIAGNOSIS:
1. Warm the transmission to normal operating temperatures.
2. Using the DRB IIIò, perform a torque converter clutch (TCC) stall test. The stall test
has been revised so that the TCC remains engaged for a period of four (4) seconds.
NOTE: THE DRB III MUST BE OPERATING AT RELEASE LEVEL 50.4 MDS2
SYSTEM CIS CD2067 OR HIGHER (AVAILABLE THE WEEK OF OCTOBER 2,
2000) IN ORDER TO PERFORM THE REVISED TORQUE CONVERTER
CLUTCH STALL TEST. DO NOT USE EARLIER VERSION STALL TEST TO
DETERMINE CONDITION OF THE TORQUE CONVERTER CLUTCH.
3. If the engine stalls as a result of the TCC stall test, then perform the Repair
Procedure.
4. If the engine does not stall, as a result of the TCC stall test, then further diagnosis is
required. The technician may want to consider the following components during
their additional diagnosis: a cut or worn input shaft seals, a missing pump lock-up
circuit check ball, or worn converter hub, input shaft, reaction shaft, and pump rotor.
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system, or
transmitted, in any form or by any means, electronic, mechanical, photocopying, recording, or otherwise, without written permission of DaimlerChrysler Corporation.
21-11-00 -2-
PARTS REQUIRED:
1 04617015 Plate, Pressure Boost Valve Cover (46RE)
1 02464324AB Gasket, Trans Pan
10(AR) 05010124AA ATF+3, Transmission Oil Type 7176 (2000 M.Y.)
10(AR) 05013457AA ATF+4, Transmission Oil Type 9602 (2001 M.Y.)
REPAIR PROCEDURE:
1. Clean the pressure boost valve cover plate to remove any dirt or rust inhibitor prior to
installation. The revised cover plate will have a 1.75 mm (0.069 inch) orifice hole
versus a 1.22mm (0.048 inch) orifice hole in the original plate. Make sure it is clean.
2. Using the appropriate Service Manual, Group 21 – Transmissions and Transfer Case,
replace the transmission pressure boost valve cover plate p/n 04617012.
3. Verify fluid level after warming up the transmission and cycling the shift lever several
times.
4. Verify, and if required, adjust the transmission shift linkage and the transmission
throttle valve cable per the appropriate Service Manual procedures.
Jun 10, 2010 | 2000 Dodge Ram 1500 Truck
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
