Question about Lexmark E332n Laser Printer
I have a USB Cable connected to it but it says the printer is off line. I've tried different USB Cables and it just won't print. I'm lost please help me!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Lexmark Expert
  • 259 Answers
Please assure the number of port USB in setting properties with your plugin the your lap top.
I have a USB Cable - edy_bubat_4.jpgif doesn't changed, you can email me....
Posted on May 23, 2011
I recently purchased a Lenovo All in One wireless computer. I've plugged in the USB cable as per instructions but my X4650 printer will still not print.
Have you installed the printer drivers? Is the printer power turned on before plugging the USB cable into the computer? You could have a bad cable. Try a different cable.
Dec 13, 2014 | Lexmark X4690 Wireless InkJet Printer
Canon printer won't print wirelessly
You should call on ((+1-800-585-2494 )) Toll Free Canon and get help for Canon.
Toll Free Number.
Oct 24, 2012 | Office Equipment & Supplies
Pc won't accept printer via usb connection
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works?
Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Mar 25, 2012 | Computers & Internet
Message printer offline
Hi
How about disconnecting it completely from PC and from power.
Wait a few minutes and then connect again.
Clear any paper jams and print queues.
Mar 04, 2012 | Canon MP270 All-In-One InkJet Printer
Deskjet F2180 not printing with Mac OS X 10.4.11
When you installed the new software did you delete your old print setup in the printer preferences as it may be conflicting with the new driver. I would delete all appropriate hp F2180 printers from the printer preferences and then install the print software again. When you do that does your printer show up? if it does not show up there could be a problem with the usb cable or the usb port on the back of your mac, swop it into another usb port, if it still does not show up, use a different usb cable. Hope this helps.
Jan 09, 2012 | Office Equipment & Supplies
I've try to connect my HP laserjet 5p printer to my mac g4, I purchased a USB cable. It prints unreadable text and won't stop, any ideals?
Make sure that you are using the correct drivers for your printer, run through the printer setup again and then check the print.
Jul 13, 2011 | HP LaserJet 5p Printer
I've been using a dell 3100 through a home network for several years. Suddenly I can't print. The network can't find the printer. I can print to it if I connect through USB. I have tried...
Hi
Please check the mention below option
1) First you get any error in your printer screen
2) If you are print through Network please ping your printer if you are not getting the print.
Open command prompt and type ping 192........your pinter ip, if you r getting reply to your printer
its mean your connect to printer.
3) Remove your printer driver and install again.
Jun 01, 2011 | Dell 3100cn Laser Printer
My dell 1815dn when printing also prints random symbols on top of the document. It varies from one line of random symbols at the bottom of the page to about 4-5 lines of random symbols sometimes. I've...
This is most probably a corrupt driver so try the following:
1. Open Printers and Faxes on your computer and delete the driver for your printer. Then go to dell.com and open the drivers and downloads tab. Download and reinstall your printer. If the printer is still printing out symbols, it's most likely either a problem with your connection or with the printer's hardware.
2. Try using a different cable to connect the printer and computer. If you don't have one, connect and install the printer to another computer. If this stops the symbols then you will need to buy a new cable. If it does not then it is most likely a problem with the printer's hardware and you will need to get the printer serviced.
Thank you for using FixYa!
May 25, 2011 | Dell 1815dn All-In-One Laser Printer
I am going to connect two pc's together useing a male to male usb cable,the problem I have is that one pc is xp pro and one is windows 7 64bit Home premiem. Any help would appreciated. Regards,Gary
There are several different kinds of USB-USB cables on the market. The one used to connect two PC's is called "bridged" (or "USB networking cable"), because it has a small electronic circuit in the middle allowing the two PCs to talk to each other. There are the so-called A/A USB cables that, in spite of having two standard USB connectors at each end, don't have a bridge chip and cannot be used to connect two PCs. In fact, if you use an A/A USB cable you can burn the USB ports of your computers or even their power supplies. So, these A/A USB cables are completely useless. A/B USB cables are used to connect your computer to peripherals such as printers and scanners, so they also won't fit your needs.
Thanks
May 01, 2011 | Computers & Internet
Whenever i try to print anything my printer prints the first 5 lines or so and then just stops and moves on to the next page where it print the first 5 lines before giving up again.
What type of document are you trying to print(PDF, MS Word doc, etc)?
Is the printer connected via USB cable, Bluetooth?
First thing I would do is try printing a different document or even a different type of document.
If printing different documents results in the same problem then I would uninstall the current drivers, download the latest drivers from Canon, then install those drivers and try printing again.
Also, if the printer is connected to your computer via USB cable verify the cable has no exposed wiring or try a different USB cable.
Mar 12, 2011 | Canon MP610 Photo All-In-One Printer
Lexmark E332n Laser Printer Logo
225 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
