Question about Adidas Response II Twin ADP1867 WW Watch for Men
Dont know how to reset the battery on my adp1867 watch. Changed the battery and cant get display back up. No ac areas inside face or outside
I just replaced the battery in my Nooka Zub Zen-V, now the display just flashes nonstop. I have tried pressing all four buttons for up to 30 sec. and the entire display turns on but when i release any of...
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.Shortcut battery with AC contact. AC can be found on the sides of watchlb_icon1.png movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs...
Oct 16, 2013 | Nooka ZOT V - White Face - White Strap...
JSprings Movement, Seiko VF62, battery change
Jan 22, 2013 | Watches
I am trying to short the AC pad on my watch to get it back to working mode, but i can't figure it out!? anyone with some infooooo
I change over 10 batteries per day, i just take tweezers and touch the battery and or the plate and then just touch all around the outside area with the other side of the tweezers!! Around the area where you see AC and very gently!!
Aug 28, 2011 | Watches
I have an old Casio watch 863 SDB-500W, I have just change the battery . Light is working but nothing is display. How to reset it ?
To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Jul 24, 2011 | Bulova Watch
No digital display , or indigo light
battery dead. take off back cover.clip inside needs small sc rew driver or push pin. to open it.tweeswers pull out . put in new one same number. grease gasket and rest. may need to reset inside. ac / point inside movement to top of battery for 4- 5 secs.tweesers
Jun 17, 2011 | Timex Watches
I recently changed the battery on my casio 437 watch and now it won't turn on
There is a 437 stamped into the back of the case for one of the two versions (437 and 438) of Casio WR watches, with the 437 being the kind with raised rubbery number buttons. The model no. for the 437, also on the back case is CA-53W, useful for ordering parts (see below). These instructions are for the 437 but should be useful in many cases for other Casio watches, with numbers other than 437 or 438 on the back of the case. For example, the resetting process described in step 5 below appears to be common to many if not all Casio watches. There is no manual on the casio.com website for many watches, including the 437 and 438. There are no instructions for changing the watch battery in the manual for the 437 or 438 either, nor for many if not all Casio watches. If there is a 438 stamped on the back of the case, the chip is the same as on the 437. The buttons on the face of the 438 watch are flat plastic rather than raised and rubbery. The two buttons near the top serve the same function on the 438 watch as the right side buttons on the 437. The left top button on the 438 corresponds to the top right side of case nonindented button on the 437. The right top button on the 438 corresponds to the bottom right side of case lower indented button on the 437. Save time and money by replacing the battery yourself If you send your Casio watch off to have the battery replaced, it will likely cost you about $30 USD. Many jewelers will routinely send a Casio watch off for battery replacement rather than replace the battery themselves, so these instructions may help save you from delays and expense if you do it yourself. Likewise, jewelers may find these instructions useful for satisfying customers by replacing the battery on the spot rather than having to send the watch off to Casio. Materials needed a. 5/64" Phillips head screwdriver (A set of different size screwdrivers in a small black plastic case, including the 5/64" was bought for $1 USD at a local Dollar Tree store in the USA.) b. Watch battery identically numbered to the dead battery on the watch (2016 on 437 case back number) c. Metal tweezers to reset the watch d. Sil glyde gel grease or any other grease, to maintain water resistance f. Toothpick or similar to spread grease in O ring slot g. Ziplock plastic bag or bowl to hold the 4 small screws so they don't get lost Instructions on replacing the battery and resetting the watch 1. Take off 4 back screws, using the 5/64" Phillips head screwdriver. One screw was balky and needed to have the screwdriver handle attached to a vise grip pliars, with the watch held in the other hand and rotated. Putting the screwdriver handle in a vise would also work to stabilize the screwdriver, while turning the watch held in one hand. Set the 4 small screws aside in a ziplock bag or bowl. 2. Remove the red cellophane cover on the battery, held by two tabs cut into the cellophane fitting into a slot on the metal hold down battery strap atop the battery. 3. With a fingernail or toothpick (nothing metal), slide the battery to the side, out from under the metal hold down strap atop the battery. 4. Insert new battery with fingers/fingernails, sliding it into place from the side. The side, with the battery number showing (2016 on 437 case back number) faces outward, just as on the removed battery before it came out. The watch will continue to appear dead, with nothing showing on the display until the electronics are reset in step 5. 5. Reset the electronics by using a pair of metal tweezers to simultaneously touch with metal, the outward facing side of the battery, and the brass terminal in an indentation in the plastic about 4 o'clock and about 1/8" outside the battery diameter. To aid in orientation, there is a barely visible small AC (presumably meaning "all clear") pressed into the metal near the battery and the indented brass terminal at about 4 o'clock. It may be necessary to tilt the watch in the light so the light strikes the AC so it becomes visible. Verify the display is working. Resetting the time will be in step 11. 6. Reinsert the red cellophane cover removed in step 2. It may be necessary to slide a knife or similar between the strap holding the battery down, and the battery, to make room for the two cellophane tabs to be inserted in a small air space between the strap and the battery. (When installed, the cellophane tabs do not prevent current from flowing between the top of the battery and the battery hold down strap.) If you use a knife or other metallic object to open up the strap to battery space to allow entrance of the cellophane tabs, take care not to short the battery against metal parts of the watch other than the hold down strap. Quickly glance to see make sure the display is still working after the cellophane is back in place. If display not working, repeat steps 2, 5 and 6 (remove cellophane, reset watch, reinstall cellophane). 7. Remove the rectangular O ring from the case back removed in step 1, or the case, and coat it with Sil Glyde silicone gel grease or similar, to retain water resistance. White grease or any grease should also work. Set the coated O ring on the inside of the metal case back removed in step 1. The O ring will eventually mate back with the O ring slot in the plastic case. 8. Using a toothpick or similar, coat the rectangular O ring slot in the plastic case with the same grease used to coat the O ring in the metal case back, to provide extra water resistance. Grease is nonconductive, so there should be no damage from shorting if some of the grease gets inside the watch. 9. Wipe hands clean and wash hands and/or use plastic gloves to avoid putting too much grease on the outside of the watch. 10. Replace case back removed in step 1. Screw in the 4 removed screws with your 5/64" Phillips head screwdriver.
Dec 21, 2010 | Casio Watches
I replaced the battery in the watch, programed the alarms , now the chime doesn't beep. how do i get that back?
As you are not watchmaker, you definitely lost coil spring, which is transmitting sound signal from watch's movement to the sound membrane. Coil spring is very tiny and this happens very often with people who do not know how the watch is built. No worries, though. Any nearest watch repair shop can fix it. Rate me, plz.
Mar 25, 2010 | Casio G-Shock G2900F1V Wrist Watch
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
When I press light buttopn in the middle the display goes blank
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Dec 06, 2008 | Casio Baby-G BG169-2V Wrist Watch
I have changed the battery in my Casio 1604 a200 watch but now the screen isn't displaying correctly. Is there anyway of resetting the watch?
I realise this post is 4 years old now but what the hell! If you open the back of the watch you will notice in the top left corner a small hole with the letters AC above it. Push something metallic into the hole to make contact with the metal backing. This will reset the watch and the display should then be fine.
Shane.
Apr 15, 2008 | Casio Watches
Adidas Response II Twin ADP1867 WW Watch for Men Logo
47 people viewed this question
Top Adidas Watches Experts
Gil Shultz
 Mikey
Mikey
Are you an Adidas Watch Expert? Answer questions, earn points and help others
