Question about Sony Playstation 3 (PS3) Console
MY wireless head set will not connect to my ps3 but was recently connected and now nothing.
  • 50 Answers
That can happen sometimes. see in the headset manual how to reset it and then connect again. should work fine
Posted on May 23, 2011
Connect to wifi on blackberry and ps3
It is just be a matter of synching the blue tooth system of the blackberry to that of the PS3. Assuming the PS3 is not currently connected to the web or connected to a modem, you should be able to search for the PS3 by using the Bluetooth search tool in the Blackberry setup menus. Then for headsets,set those up through the PS3 by turning on the head sets, and then using the Blue tooth set up utility of the PS3 to search for the head sets.
Otherwise If you do not have Wifi active currently and don't have good cellular coverage in your area, you can use a Wifi Bridge Dongle (connector cable) like this one, there are others available too.
http://www.espow.com/wholesale-wifi-bridge-dongle-wireless-for-dreambox-xbox-ps3.html
to connect the PS3 to your home computer and use it as the hub assuming you ahve it connected to DSL or broadband. headsets would set up the same way.
Jan 04, 2012 | Sony Playstation 3 (PS3) Console
I am tryn to sign in,through the PS3 onto my internet. how do I get connectivity?
If you are trying to connect via a wired connection you should be able to just plug in an ethernet cable from your router/modem straight to the PS3 and it should connect.
If you are trying to connect to the internet via the PS3's built in wireless capabilities head under network settings via the XMB and scan for nearby wireless connections. Once it has found yours select it and enter your password if needed.
Mar 14, 2011 | Video Game Consoles & Games
I have connected my PS3 to the internet wirelessly before but I have recently moved into a new home. I consistently get the 8013013d Error code when trying to connect to the internet... But my room mate...
Hello :D
8013013D "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key PS3 can't handle WPA2 only WPA or none
May 21, 2010 | Sony Playstation 3 (PS3) Console
I have a PS3 120GB. Recently installed Hi-Def and wireless in home. The wireless router is not in same room with PS3. Is there a device I can add to the PS3 to enable the wireless features, or does it have...
there is already a built in wireless device for the internet. id say its not working because you need to put your I.P adress, subnet mask, router and DNS numbers into playstation. go to settings on ps3. then network settings. manually install all these numbers. you should be able to get them off your laptop or computer when its connected to the internet. if you cant ring your internet provider to grt them.
Jan 10, 2010 | Sony Playstation 3 (PS3) Console
ORB Ps3 controller not connecting
I recently brought a ORB Wireless PS3 controller, and having trouble connecting it. There are no instructions which came with it and i have tried everything to connect.
Thanks
Dec 28, 2009 | Video Game Consoles & Games
Cannot connect via wireless network, router not being detected by laptop or ps3. I can connect to internet on desktop via modem through router. When trying to detect wireless network via laptop and ps3...
stupid question : is Wifi turned on ?
Go to your administration environment of your router ( typically : http://192.168.1.1 ) and check the config of the wireless settings
Aug 14, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
I want to get internet on my PS3
you must do some easy steps as following
you need to Connect your wireless routermag-glass_10x10.gif toyour modem.
You can do this by refering to your routers manual,or just connect them if you know what to do. Step2Once you have connected your router,turn it on,and check that itsrunning ok.Once you have checked that,hop on to your PS3. Step3 On the playstation,Head to settings -> network -> connection settings.
Then,select wireless connection and follow along with the set up.
If your router is not on Unsecured,i surgest you set up manualy then automatic. Step4 Once you have finished,Your playstation will say/tell you that the ip and internet connectionmag-glass_10x10.gif are ready. Step5 (WIRED CONNECTION).
For a wired connection,you will need a ethernet cable which you can pick up for $10 at your nearest electronic store. Step6 Connect the wire into the back of your modem,and the other end into your ps3. Step7Goto settings -> network -> connection settings and then selectwired connection.Follow the setup.(automatic is best for this setup) Step8 ONCE that is all done,Your ready to use the net on your ps3
Please rate if helpfully! :)
Apr 06, 2009 | Sony Playstation 3 (PS3) Console
IP Address "Failed"
restore your default settings. check your security key and you shoudl be good to go. it's nothing with your ps3 and probably just something with yoru router. also try restoring the default settings and just connecting directly to your router or your modem with an ethernet cable
Dec 29, 2008 | Sony Playstation 3 (PS3) Console
Connecting my PS3 to the internet
Do you have a Security keu enabled on your wireless router??
Do you have a wireless Router???
Feb 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 bluetooth connection
I think you are mixing up two different technologies. You said you have recently bought a Wireless Router and when you try scanning for Bluetooth devices you can't find it?
First of all, Bluetooth isn't Wi-Fi. You should go to Network Settings under Settings in the XMB and choose for a Wireless Connection and then let it scan.
Be sure you don't have a 40 GB PlayStation 3 since they don't have Wi-Fi.
I hope this helps. Please rate.
Greetings,
DarkNeogen.
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
