Question about Saeco Incanto Classic Espresso Machine
My Saeco Vienna Digital will not generate steam. Only hot water comes out of the nozzle when the machine is set to "steam"
  • 1 more comment
  • ianiven May 24, 2011
    Can you advise how to remove the side panels. I have removed the top cover.
  • ianiven May 25, 2011
    I do not understand your answer to my question regarding how to remove the side covers. What has the switch got to do with my problem. Your first comment suggested I remove the top and side covers to check the steam boiler for calcium buildup. As I indicated, I have removed the top cover but cannot remove the side covers (housing). It looks like the guts of the unit should pull straight up out of the housing, but it won't. Is there a release at the bottom?
    I am also not sure that your solution is correct. The unit was fully serviced 6 month ago and last week I did a chemical clean. I therefore do not think it is calcium buildup. What about the steam boiler? Hot water only comes out of the nozzle when set for steam.
  • ianiven May 26, 2011
    My question - "how to remove the side panels (housing)" has still not been answered. If I can't remove the housing I cannot check anything.
    Would it be the fuse as I get hot water - but no steam from the nozzle?
    Guru:
  • 352 Answers
Hello.
This issue is due to the secondary coil not working. it is a multi coil heat system to allow for different settings, this coil can only be accessed by a specialist unfortunately.
Regards GM
Posted on May 28, 2011
    Guru:
  • 1,833 Answers
If you think that the steam boiler is ok, then you may have a fuse that is blown for the steam boiler.
Posted on May 26, 2011
  • 252 Answers
Hello first of all
Well i no what the problem is the selector knob is faulty is pretty common with this machine i am not sure if in your paperwork you have a parts breakdown but reorder switch if possible and your problem will be taken care of.
if you need anything else just ask please before not leaving 4 starts and a testimonial
Posted on May 25, 2011
  • 794 Answers
Hi ianiven,
Your Saeco Vienna do have a separate heating system for steam. One of the common reasons why there's no steam produced is that the machine is full of scale. To clean it this requires you to remove the top and side panel. Follow the Teflon pipe from the steam wand and it will lead you to the steam solenoid valve and the small copper steam heating system. You have to disassemble both. You can then, remove any scale and dirt. After cleaning, assemble the machine.
Hope it helps.
Thank you for using FixYa.
Posted on May 24, 2011
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
No water / steam coming out of steam wand
Check the end of the nozzle it might be blocked, if not, descale machine.
Aug 24, 2010 | Saeco Vienna De Luxe Espresso Machine
Steam function SAECO Vienna Exclusive not works
Check the thermostat on the steam boiler, that could have tripped, or the element on there could be damaged.
Jan 23, 2010 | Saeco Vienna De Luxe Espresso Machine
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco vienna digital not steaming !!
Hi
If you get water through the wand, you may have a thermal fuse that is blown or the element in the steam boiler is gone. Let me know if you need one.
May 26, 2009 | Saeco Vienna Digital Coffee Maker,...
Saeco vienna "machine ready" light (second light) blinking--not allowing to dispense coffee.
Try to open the steam knob and make a cup of water(Tea).
Best regards
/Mirran
Oct 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna superautomatica Machine
if you open the steamer, does it work correctly? and if u request hot water does it come out?
if not, then its the pump..
Nov 02, 2007 | Saeco Vienna Espresso Machine
I had this problem on my Saeco Vienna Digital a while back. I read somewhere just to keep on ventilating, even if it took 20 hoppers of water. Sure enough after about 16 cycles, I heard a change in the noise and looked to see the ventilate sign was gone.
Oct 24, 2007 | Saeco Vienna Digital Coffee Maker,...
Saeco Incanto Classic Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
