Hi oakleafwoodw, sounds as if the brake master cylinder has busted a seal allowing the brake fluid to leak by cylinder when you push the brake pedal giving you no or very little pedal pressure....it is located under the hood on the drivers side firewall, you will see all the brake lines attached to it , remove those and the two bolts holding it on,take it with you to auto parts store for a rebuilt one , they will keep your core for rebuilding, other wise you pay a core charge., verify that they have the one you need before hand, get a quart of dot 4 brake fluid, hook it up, and bleed air from the brake lines starting with wheel cylinders in this order Right rear......left rear.....right front.....left front...making sure to keep fluid level topped off in the master cylinder during the whole bleeding process or you will pump air into lines....OK!! caution: you should not drive it until you have good brakes!! you said they still work but if you had to stop suddenly ,it won't do it.
