Question about E-Machines M5405 Notebook
Bios in an emachines M5405
I'd like to install a Turion CPU, but the current bios will not accept it. Do you know of a bios I can use in this machine that will recognize the Turion?
Problem upgrading CPU
Try to update the BIOS with the old CPU in, if not the new CPU could be faulty, yes I know it's new but it is entirely possible
Apr 19, 2014 | eMachines W3619 PC Desktop
ECS MCP61PM-GM
Lan card Intel Lakeport-G i945G / Intel 82801GB ICH7 I am receving audio voice
Feb 06, 2014 | Computers & Internet
How to i get my amd turion 64 x2 tl-50 to factory reset?
You can reset your BIOS to factory default. There is an option there. Or you may only change the settings about CPU to the default or automatic.
Aug 18, 2010 | AMD Turion 64 X2 TL-50
Can I install a better CPU into my Toshiba Satellite P305D-S8834 17 1 Widescreen Notebook Computer then the AMD Turion X2 Processor RM-70 it came with?
Changing CPU is a serious change. When your unit was built the processor speed and type were written into the BIOS. When we change the CPU to a different type there is a chance that the BIOS will not recognize it and refuse to boot up. Also Windows was installed with the original CPU and a major change in hardware could mess up Windows.
I did some research and found this model comes with a 2.0-GHz AMD Turion X2 Dual-Core RM-70 CPU and 4GB of RAM. This is not the fastest CPU that can be put in a laptop but a very good one. (faster than mine)
I can guide you through the steps to replace it but my advice is stick with what you have until it breaks and buy a faster laptop. The upgrade won't gain you enough to justify the expense.
May 21, 2010 | Toshiba Satellite P305D-S8834 Notebook
Where can I download Notebook M54g sound drivers
Hi. You need full model of product. You should find it on the bottom of the laptop somewhere. When you find it go to this website http://www.emachines.co.uk/em/customercare.do?ctx1w.att21k=2&LanguageISOCtxParam=en&sp=page11l&CountryISOCtxParam=UK&ctx1l.c2att1=17&rcond3l.attN2B2F2EEF=3624&rcond4l.attN2B2F2EEF=3912&CRC=99015199 and choose your sound drivers. Download and install. Please don't forget to let us know if this was helpful. Thanks and good luck
Apr 23, 2010 | E-Machines M5405 Notebook
AMD Turion 64x2 Processor Upgrade Problem
Yes it's the BIOS, which holds a list of supported CPUs (with the right min/max settings for Vcore, FSB, multiplier (or HyperTransport as it's called for AMD chips), etc.). When you put in a newer unrecognized CPU, it either runs at a failsafe (very slow) setting or won't boot at all.
The only solution is to flash a newer BIOS version which supports the CPU. I searched the Acer website and found the newest BIOS version 3315 (dated 2008-12, which is pretty new imho), which you can download (including the required flash software) here: http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_3315.zip?acerid=633643256207419447&Step1=Notebook&Step2=Aspire&Step3=Aspire 5050&OS=V10&LC=nl&SC=EMEA_18
Perhaps you already have this BIOS version and I'm not sure wether your new CPU is supported by this BIOS, but you might give it a try.
Please note that flashing your BIOS might fail & brick the laptop and is at your own risk, but when following the instructions carefully, it's only a very small chance things go wrong. I've done it a dozen times without any problem ...
Aug 11, 2009 | Acer Computers & Internet
Turn computer on, screen stays blank.
Hi there Eliot.
It does sound like a graphics issue, go here and select "downloads" for all the drivers for that computer .
http://www.emachines.com/support/product_support.html?cat=Notebooks&subcat=M%20Series&model=M5405
Post back if you have more problems and good luck!!
Feb 14, 2009 | E-Machines M5405 Notebook
Does the motherboard for the model w3107 e machine with the sempron cpu processor driver upgrade deemed compatiable
The AMD Sempron 3100+ Processor is the highestspeed CPU you can run in the W3107 E-machine. No there are no drivers that need to enabled.The system bios sets up the cpu. Did you install this CPU?
Your E-machine:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W-Series&model=W3107
Jan 07, 2008 | Computers & Internet
E-Machines M5405 Notebook Logo
234 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
