Question about Foxconn G31MXP-K Core 2 Quad/ Intel G31/ DDR2/ A&V&GbE/ mATX Motherboard G31MXPK
Mother board not reading sata hard drive - Foxconn G31MXP-K Core 2 Quad/ Intel G31/ DDR2/ A&V&GbE/ mATX Motherboard G31MXPK
  • Foxconn Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electical extension or fan lead can cause this problem
hope this helps
Posted on May 23, 2011
  • Brian Sullivan
    Brian Sullivan May 23, 2011
    another possiblity if you have a set up disk
    Restart your computer with the XP Setup disk in the CDROM drive. If you are prompted to press a key to start the computer from CDROM, do so quickly. Otherwise it may try to boot from the hard drive. After a few minutes, you'll see a prompt to press the R key to start the Recovery Console. When Recovery Console starts, it will prompt you to enter a number corresponding to the Windows XP installation that you need to repair. In most cases, you'll enter "1" (which will be the only choice). If you press ENTER without typing a number, Recovery Console will quit and restart your computer. Enter your Administrator password. If you don't enter the correct password, you cannot continue. At the Recovery Console command prompt, type fixmbr and then verify that you want to proceed. Your damaged MBR will be replaced with a shiny new one, and you should then be able to boot your system normally. In some cases, you may need to repair the boot sector in addition to the MBR. If your system still doesn't boot properly, repeat the steps above, but issue the fixboot command instead. Hope this helps
Nitrotrike
  • 589 Answers
SOURCE: user's manual
You shouldn't have to change any jumpers. The only jumper I see is to reset the bios.
Posted on Jan 10, 2008
  • 1019 Answers
SOURCE: 250gb sata hard disk to 845 glad mother board
The Power Cable is usually supplied With The computer Cases PSU. newer Power-Supply-Units Usually Have 1 Or 2 SATA Power Cables Attached.
secondly, the motherboard will provide the SATAs Data Connections. ( Usually look Like a Black Plastic ) Letter L shape connector.
Solution. Upgrade Motherboard And Power-Supply-Unit.
Alternative, look on e-bay or similar site, to find a SATA/PCI Card. And A SATA Power Supply Cable.
Mike @ Compurepair.
Posted on May 12, 2008
  • 341 Answers
SOURCE: dell gx280 hard drive and dvd drive
You can buy adapters for this very thing. Less than 20 bucks at most computer stores. I looked on newegg and they were 11.99.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822998001
Posted on Nov 30, 2008
  • 4 Answers
SOURCE: Hard disk is not detecting when I try to install windows 7
Hi
You should find the drivers you are looking for on the Asus website.
Here's the link to their download page,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope that help,
MK Support
Posted on Mar 15, 2009
yboyandrei
  • 828 Answers
SOURCE: Can't connect SATA Hard Drive to MSI PT8 Neo-V
Figure out this problem is motherboard.
If this problem still occur, then how about to use and Plug in Play "PCI to IDE/SATA Card. I know it's available in the market or buy a new Motherboard with SATA ready.
Posted on Oct 01, 2009
I have amd 2800+ and asus mother board my system support id harddrive but not supported sata hard drives why
Please download the latest bios driver and upgrades for SATA operation and read the procedure for SATA application, in the Asus home page, write also your MoBo's type.
Hope that helps!
Apr 29, 2012 | AMD Sempron 2800+ CPU with Mother Board...
Any sata hdd can't dected by the mother board but any sata dvd dected by the mother board. what kind of procedure i followed now?
Your motherboard CAN detect a SATA device.
Your motherboard DOES detect your SATA optical device.
Your motherboard does NOT detect your SATA disk-drive.
This suggests that your disk-drive is "dead".
Exercise the WARRANTY on it, to get it repaired/replaced.
Or, if the warranty has EXPIRED, purchase a new SATA disk-drive.
Feb 03, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Not read sata hard disk althought i bought ide sata to data converter but mother board not read the hard
1. ensure under bios setting you have set to "enhance" mode on drive
setting.
2. ensure that all data and DC supply are in good condition
Aug 10, 2010 | Gigabyte GA-6OX Motherboard
I have some problem on my hard disk. when i am
its a simple problem ...
open your cpu and change the sata wire to another sata slot in the mother board... there will be 4 sata sloy in *********** board... you can change it to any..
try and see... it might work
good luck
Jun 01, 2010 | Samsung HD 40GB ATA-6 | HD040GJ - % Hard...
Sata power supply with ide only mother board?
Unlike IDE drive cables, which allow you to connect at least 2 drives to the same cable, SATA cables only allow one connection from motherboard to drive per cable. You can connect as many SATA drives to your motherboard as you have SATA connections.
Mar 25, 2010 | Computers & Internet
ABIT AV8 not reading SATA ASUS DVD Burner
you should contact your computer servicing centre.the problem might be of the drive.for getting more knowledge about the ASUZ mother board and SATA please make use of your users CD which is given with every ASUZ motherboard.easily understandable pictorial reprasentation of the whole mother board are given there.by that you can even find out the problem in *********** board if any. if you are convinced please rate me
Sep 22, 2008 | Abit AV8-3rd Eye Motherboard
Hard Drives -ATA and SATA
Yes, they can coexist.
May 17, 2008 | Computers & Internet
MOTHER BOARD cant read storage disk.
That sound can be the SATA drives spindle is going. Suggest you replace the drive before you can not get the data off it. Check the Mfg of the drive, it may be warranted.
Mike
Mar 30, 2008 | Intel D945GCCR Motherboard
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Foxconn G31MXP-K Core 2 Quad/ Intel G31/ DDR2/ A&V&GbE/ mATX Motherboard G31MXPK Logo
123 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
