Maytag washer man 2400aww code sub5 problem - Washing Machines
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: I have the code that
Hello & Welcome to FixYa
3E is a motor failure error code and occurs due to over current. The unit will display 3E error when the motor won't turn. You will have to check the speed sensor, wiring connections, motor windings; if everything is working including the motor then replacing the control board is recommended. Please get back to me if you have any other questions.
Kevin
Posted on Sep 03, 2011
When I start the cycle the machine won't start but a DL code comes on display panel. The book says to power of and back on and try again . We did. Same results. We are sure the door is shut properly but...
This same problem (and same codes) come up on the whirlpool duet series washers. On the whirlpool there are bad solder joints (also called cold solder joints) on the control circuit board where the spade connectors and relays that handle communications between the main circuit board and the door lock and motor control. The cure that I've done is to remove the circuit board and touch-up the largest solder points, those would be the spade connectors and relays. If you're not up on soldering techniques, you could remove the board and take it to a good appliance repair shop and they should be able to check it out for you. Good luck.
Mar 16, 2011 | Washing Machines
Error code 0e
Hi, it is the pressure switch aka water level sensor. OE is overflow error. Pressure switch is located under top cover on front right hand side. It is round and has a rubber tube leading down to the drum and a electrical connection to the board. Paid maytag man to diagnose/install cost me about $150.
There is a recall on the circuit board for certain Maytag Neptune washers. See the link below:
http://www.repairclinic.com/0098_11.asp
Take care
Jun 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Very small space, limited choices
I would recommend whirlpool since they bought out maytag .They are a great for support and warranty:)
Mar 28, 2009 | Whirlpool LHW0050PQ Front Load Washer
Changed alternator and still no cluster instruments
there are two fuses for the cluster an A fuse and B fuse. check them
Mar 22, 2009 | 2001 Dodge Ram 2500 Truck
Maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Feb 28, 2009 | Maytag Bravos 4.5 Cu. Ft. Washer
Washer won't agitate
open the back check the belt also see if u can turn it by hand. if that doesn't help call repair man .
Jan 11, 2009 | Maytag Neptune MAH6500A Front Load Washer
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
