Question about Vacuums
I have a Steam Glide 2200 which has suddenly stopped working. It ran out of water, I re-filled it and the iron will not heat up. The base lights all seem to be working but the Iron itself does not even light up. Do you have any suggestions please. Thanks Chris
  • 3 more comments
  • chrissie111 May 24, 2011
    It was refilled immediately as it always is. You cannot operate the iron without water
    as it emits a warning. I am pretty sure this is not the problem.
    any more suggestions?
    Kind regards
    Chris
    How do i dismantle the unit to check please.
    Regards
    Chris
  • chrissie111 May 27, 2011
    I will have a look at this tomorrow (sat) when i get home and let you know.
    Kind regards
    Chris
  • chrissie111 May 28, 2011
    I took the iron apart but couldn't find the fault.. I have taken it to the repair shop and the problem is the thermal fuse has blown. I have left it with them to repair.
    Kind regards
    Chris
    I took the iron apart as you suggested but could not find the fault. I have had to take it to the repair shop. It is a thermal fuse which has blown.
    Regards
    Chris
  • Vacuums Master
  • 11,800 Answers
When it lost the water the heating resistance overheated and burned. When that happened the electrical circuit inside the entire iron went out - this is why the unit lights don't come on.
To fix it you should replace the soleplate of the iron, the one that has the resistance embedded in it. But i don't think this is a cost-wise option: the part and the necessary labor would cost more than a new unit.
Posted on May 24, 2011
  • 2 more comments
  • Azrael SRL May 24, 2011
    The iron has a very simple construction it's composed of just 3 electrical elements: power cord (not it, you still get some lights on the base), a simple control board with a thermostat (it might be broken but i doubt it - it's very reliable) and a resistance. As you can see the most likely part to have failed is the resistance. That's easy to check: you just dismantle the unit and you measure the resistance with an ohmmeter - all beyond 100 ohms and the resistance is defective.
    2 screws to remove the back platter (some gentle prying will be needed), followed by 2 bolts that secure the soleplate to the body then the body unclips to give you access to the plate - be careful here as to not rip apart the electrical connectors or break the fitting clips on the body.
  • Azrael SRL May 27, 2011
    OK.
  • Azrael SRL May 28, 2011
    That fuse blows only when there's a fault - either the soleplate overheated or there has been a short. Ask them to find what happened.
Suddenly stopped steaming, tank filled steam light stays on, no steam but heats up? Problem solving in manual just states the obvious? Can you suggest anything else or will I have to contact Hoover
Perhaps Element not heating to full temperature to generate steam.
Temperature sensor may be faulty if element is ok.
1 Element or 2 ????
Sorry... No magic fix button
Open it up and start testing things.
a multimeter comes in handy here.
or
back to Hoover repair centre
Good Luck
Feb 03, 2016 | Hoover Vacuums
Why won't my bissell steampower spray water anymore?
Steam Irons and carpet machines should be filled only with distilled water. Repeated use of tap water can lead to mineral build up, clogging the tubes and vents. Using white vinegar instead of water can dissolve the minerals over time (fill and let sit) the best method is to disassemble the unit and clean the heating elements and all water baring parts.
Jun 25, 2014 | Bissell Vacuums
My steam glide russell hobs iron pours out water when used I have burnt my self a few time. It also leave the garment very wet.
Many persons put too much water in a steam iron.
Make sure that you do not fill it all the way to the brim.
Try using less water in the tank.
This may also solve your wetness problem.
Aug 29, 2011 | Vacuums
How do I clean my iron?
I am assuming that you have scale or lime build up on your iron. Make a solution of half white vinegar and half distilled water. Pour it in the water container on your iron. Turn your iron on its highest setting and set for steam. Wait about 15 minutes and turn off the iron. When water cools pour off the remaining water/vinegar solution. Fill the iron with distilled water and turn on. Let it heat and then cool then pour off that solution. Do this till the poured off water runs clear. If you have scale on the bottom of the iron you can clean that with an old toothbrush dipped into warm white vinegar. There may be easier ways to do this but this is eco friendly and it works the best of anything I have tried.
Apr 08, 2011 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
Theres water pouring out of my t fal iron's little holes when I begin to iron my shirt...why!
The iron needs to be cleaned as I have just discovered myself. I have a hinari and the instructions are as follows. Fill the water tank and turn the iron on to medium. When heated press the steam button and hold it over the sink or a container so that the water can run out of it. It will take sediments with it. The cleaning of the iron should be carried out once a month.
I experienced the same trouble and carried out the instructions and all is well again.
Jun 28, 2010 | Vacuums
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Vacuums Logo
49 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
