Question about Datamax Office Equipment & Supplies
I have a Datamax I class, Model# DMX-I-4208, before we upgraded to this printer we were able to print bar code labels with a UPC A style bar code, now it prints a Code 39 bar code. We need to be able to print the UPC A style bar code again. Can you switch bar code styles in an existing data base?
SOURCE: 4208 Datamax M Class printer Problems
After changing the size of your labels the printer needs to measure the new label length. Press the feed button for four seconds (wiht new labels loaded & printhead locked down). If this doesn't fix your problem you need to correctly position the media sensor.Make sure the short white line on the media sensor is above the label gap.
Posted on Aug 21, 2007
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
SOURCE: datamax dmx-m-4208
press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Posted on Feb 12, 2009
  • 54 Answers
SOURCE: datamax dmx-m-4206
check for the flatness of the printhead across the platen.
also check to see if the head is not worn(will be white colored at the head heat elements.
also check to see if the platen is severly worn.
Posted on Feb 25, 2009
  • 54 Answers
SOURCE: Datamax I 4208 prints slow when set to landscape
try using a seagull sceintific driver.
also if you are sending graphics (barcode) instead of an actual barcode decoded font, the printer will process as a graphic.
If serial, speed up to max, if parallel it should print quite fast
Adjusting Datamax i class
If the ribbon is moving right on the I-4208 so far that you aren't getting print on the left of your label, the typical solution is to make sure that your ribbon roll is pushed all the way in, as far as it will go (at the top center of the printer on the black hub where the ribbon and it's cardboard core slide on). Similarly, make sure that the used ribbon that is winding on to the Rewind Hub at the top front is also in (to the left) as far as it will go).
Jun 26, 2014 | Datamax DMX-I-4208 Label Printer
Dmx-4204 and zpl
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Jul 23, 2013 | Datamax E-CLASS DMX-E-4204 Label Printer
My printer DMX M-4208, can not print when i try to "Test Print" from the machine, could you help me to solve it
doni_s: After printing some labels, test print can not function properly. Reboot the printer and try the test print again.
Roberto Martinez
padrino99@prodigy.net.mx
Jul 28, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
How much does the I class actually weigh in Kg?
Hi Adam. Here is a link to the spec. sheet. http://shopper.cnet.com/label-printers/datamax-i-class-i/4014-3163_9-30719556.html#info-5
It weighs 45.2 pounds which is 20.5 KG. One Kg is 2.2 pounds. Joe
4 thumbs up please. ty
Nov 08, 2010 | Datamax DMX-I-4208 Label Printer
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
pkwc
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
