Question about Keurig B60 Coffee Maker
There does not appear to be any power in the unit. I have switched outlets, unplugged and waited, etc. but the display for the B60 unit is blank and the unit is inactive. It has worked great for 1-1/2 years and this has just suddenly happened? Any clues??
  • jrhead432 May 23, 2011
    I think it helped by confirming my own suspicion that the problem is internal and will not likely reset "on its own". I will try the suggested solution ... but I 'm not optimistic re: the outcome.
    Thanks ... I appreciate your service.
  • 6,993 Answers
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on May 23, 2011
Why does the display appear and disappear after 2 seconds of being plugged in, and I cannot get it to work?
This could be a setting for a timeout of the LCD screen.
It may be a defective product if you cannot print or send test prints.
May 25, 2014 | Staples Office Equipment & Supplies
MFC-8710DW has no power
If your Brother machine does not appear to have power,then check whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.If your Brother machine's LCD is blank, continue to Step 2.
Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
Please note Brother strongly recommends that you connect your machine to a surge protector.Because To protect your investment against power surges and lightning,
In particular, we suggest that you use a surge protector that is compatible with both standard A.C. power cords and telephone line cords. Surge protectors equipped with telephone jacks will assist in insulating your machine from any power surge that might travel through a telephone line.
If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding the On/Off or Power Save key. This key is located in the upper-right corner of the control panel.
If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
-OR-
Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
If your Brother machine still will not power on, please contact Brother Customer Service.
Or
Please Follow Us On Brother Printer Support
Jan 02, 2014 | Brother printerall-in-onelaser mfc8710dw
No power when I turn the unit on
  1. Verify whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.
    1. If your Brother machine's LCD is blank, continue toStep 2.
    2. If your Brother machine's LCD displays a message other than the date and time, please refer to the FAQ about the message being displayed for further information.
  2. Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
  3. If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding theOn/OfforPower Savekey. This key is located in the upper-right corner of the control panel.
  4. If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
    -OR-
  5. If your Brother machine still will not power on, please contact Brother Customer Service.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Nov 14, 2013 | Brother MFC-J220 All-in-One Color Inkjet...
ERROR CODE 0xc19a0002
Switch on your printer.
Press and hold the * key.
Press the # key and release both keys.
Display should say Enter Special Key Combo
Press and releasethe key in sequence 1, 2 and 3 buttons.
display says "support" R0631M
Press and release the right arrow button until the display says " System Configuration Menu".
OK button.
Display should say Hardware failure status. If not there already, Arrow Key over to Hardware failure status
Press and release the OK button.
Display should say Hardware failure status: Clear. Press OK to clear.
Press and release the OK Button. Message changes to Hardware failure status Cleared. Press Cancel to continue.
Press and release the CANCEL button as many times as necessary, so that, either the Welcome to Photosmart Express screen appears, or, the Ink System Failure screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
Turn the unit on. The printer may display message USE POWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. Press OK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page..
Oct 11, 2013 | HP C6280 Photosmart All-in-One Printer...
0xc19a0002
OK button.
Oct 10, 2013 | HP Photosmart C6280 Printer
My HP all-in-one printer model C5580 will not print. In my display it keeps giving me an error code of B808268C. I have shut it off and on, checked all connections but nothing helps.. It acts like
1. Verify that the unit is switched on.
2. Open printer and remove ALL cartridges.
3. Unplug the power cord from the printer. (not from the outlet)
4. Now unplug the cable form the wall outlet
5. Wait 30 seconds.
6. Plug the power cord back into the printer.
7. Plug the power cable directly to the wall outlet (not to a surge protector, etc)
8. Open the top cover and reinsert the cartridges.
9. Turn the unit on.
10. Print a document to test
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2012 | HP Photosmart C5580 All-In-One InkJet...
Error code 0xc18a0201
Hi.
The code means Ink System Failure. First disconnect power cord to reset the printer and test using different cartridges.
If that does not work try the procedure below:
"Press and hold the "left arrow" key.
Press the "Setup" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release the "OK" button
1. Press and release the right arrow button until the display says "System Configuration Menu".
2. Press and release the "OK" button.
3. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
4. Press and release the "OK" button.
5. Display should say "Hardware failure status: Clear. Press OK to clear".
6. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
7. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use.
NOTE: If the error is still there, or reoccurs replace the unit."
Procedure from http://www.fixyourownprinter.com
Apr 23, 2011 | HP Photosmart C5180 All-In-One InkJet...
LED Display window is blank
try pressing all 3 size buttons down and then with them down press menu, wait then unplug and wait 10 seconds or so then plug in and it should have re booted.
Jan 04, 2011 | Keurig B60 Coffee Maker
Monitor say clear paper jam then press ok. It indicates that the problem is at the back of the printer (the protruding compartment) but I have taken this off examined everything and there is definitely no...
The clicking could be because it thinks there is a problem. Try doing the procedure for resetting the memory on the printer...
(For step 4, do # 3, # 6 as well)
  1. With the unit turned on, Press the Power button and turn off the HP All-in-One.
  2. Unplug the power cord from the Wall Outlet and then from the Unit.
  3. Wait for 20 seconds , Plug the power cord into the wall outlet.
  4. Press and hold # and 9 while plugging the power cord back into the unit. Continue holding the buttons down until the display goes blank or it shows a message.
  5. If the printer does not turn on automatically, then turn on the unit by pressing the Power button & follow the instructions that display on the HP All-in-One to select the settings
Aug 31, 2009 | HP Officejet Pro L7680 All-In-One Printer
Scan not functioning. Provides NO ERRORS.
Unplug the power cable from the All-In-One when there is still power in the unit.
Also unplug the power cord from the wall outlet.
Leave the cable unplugged for atleast 1Min time.
And connect the cable directly to wall outlet with out any surg protector (if you have a different outlet try with that)
Then before connecting the cable to the All-In-One press and hold the # and no 9 button do not release the buttons untill it comes up with a mesage as reset (or if the screen goes blank then release the keys and turn the power on)
Then press the setup/menu button and then press the right arrow key till you see print reports> the press Ok and scroll to print test page and check if it is functioning properly.
Then try a color or Black copy and check.
Good Luck
Sep 12, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Keurig B60 Coffee Maker Logo
452 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
