Question about Xerox DocuColor 12 Color Copier
I HAVE A REPEATED PAPER JAMES THE PAPER WILL NOT PASS THRU NO MATTER WHAT SIZE SHEET I USE
    Problem Solver:
  • 6 Answers
Check for breakage or resistance in the paper path. does the paper reach the fuser module? or does it get stuck while exiting? clarify please.
Posted on Jun 04, 2011
Unexpected paper size
Usually caused when the pickup roller pulls more then 1 sheet of paper thru or you simple dont have the backstop or side guides in the tray set for the paper size your putting in. I all these fail, could have the tray set to any size but the driver is wanting to print on say legal size but you put letter size in the tray instead triggering the sensor error... hope this helps...
Feb 07, 2013 | HEWLETT-PACKARD CP1025nw Laser Printer
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
Manual laser jet 4
The paper size selection knob or MP paper size does not
match the installed paper or more than one sheet of paper
was picked up.
Oct 23, 2011 | HP Hewlett Packard LaserJet P3005n Printer
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
I have this printer and says Rec. Paper jam but there is no paper in the printer.
which model do you have
may be some part of paper lying in it
try to pass thru full a4 size paper in it if it pass thru it will came with torn paper stuck in the paper path
Aug 13, 2010 | Office Equipment & Supplies
My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
Feb 22, 2010 | Office Equipment & Supplies
Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
Can not figure out how to print on any custom size paper
If you go to your printer properties, preferences or advanced, on the Main menu, is paper sizes,
click the little tab, look at the sizes list,
scroll to the bottom, and you will see.
Custom sizes by User, create your User Defined cusom size.
check your paper tray is setup correctly.
should be good now.
Regards
Richard.
Apr 20, 2009 | HP Photosmart C7280 Laser Printer
False Paper Jam Message
Probably a jam sensor is dirty or stuck. Look through the paper path for a stuck plastic sensor arm, or dirt or paper dust on photocell typr sensors.Paper sensors are normally located near where paper feeds, and where it exits the machine. The paper must pass over these sensors as it travels through the machine.If a scrap of paper is left on the sensors, they will report it as a jam. If you can, try manually pushing a sheet of paper through the printer, ONLY in the direction it normally feeds. This may free up a stuck sensor arm, or force out the jammed scrap.
Jun 08, 2008 | Brother MFC 420CN All-In-One InkJet...
Xerox DocuColor 12 Color Copier Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
