Question about Alcatel Newbridge MainStreet 3600 Multiplexer
We connect 8 analog lines to a 3612 on one end compressed lines to 16 k each accross a data circuit then break them back out on a 3612 on far end. Calls will be up for a minute or 2 then drop. Call quality is perfect until the drop
  • 20 Answers
There are many reasons why the call will be dropped. The call will be dropped when you aggregate link between the nodes fails, if this is not the case monitor the connections on the node and see if the connections stays up. If I would guess it could be the PABX that is dropping the calls and not the nodes.
Posted on Nov 18, 2011
I keep getting error message.....Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; GTB6.6; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR...
Does this only happen when you try to access a page from 'www.comcast.net' ?
Within Internet Explorer, click Tools.
Click Internet Options.
Under the "Browsing History" section, click Delete,
to remove any "temporary" files.
Then, try again to access COMCAST's web-site.
Nov 12, 2010 | Microsoft Internet Explorer 8
Vertical lines accross the screen
Vertical lines running down the screen is indicative of a data failure to the screen itself, which means either the screen is starting to fail or the data being transmitted through the data cable is being interferred with. Put a hand on either side of the monitor and give the monitor a light twist....does the line disappear? or do more lines appear...in either case, there is a problem where the data cable attaches to the lcd panel itself. You can try to change out cables, if that doesn't correct it, then the panel may have to be replaced. If you have the option of trying the computer on another monitor that would be the first step in seeing where the problem lies.
May 24, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
There are 3 fuel lines on my Poulan 2150, 2 - 1/8"...
The 'vent looking device' should be the fuel filter--remove it and make sure it is not plugged. The other end of that line should go to the carburetor inlet port near the top. When you get the line connected, pump the primer several times (tank is filled with fuel mix and the small line returning to the tank is pulled loose from the primer port) to see if it pumps fuel through the carburetor into the primer bulb. If it does not, swap the line from the carburetor to the other primer port and retry pumping again. If fuel fills the bulb, then plug the line from the tank to the vacated port on the primer. This will pump excess fuel back into the tank. Hope this helps!
May 17, 2010 | Garden
Need 3612 mainstreet J8 pinout configurations DB9 to RJ45
DB9 -----------------------------------> RJ45 1 ---------------------------------------> 8 2 ---------------------------------------> 4 3 ---------------------------------------> 3 4 ---------------------------------------> 7 5 ---------------------------------------> 5 6 ---------------------------------------> 6 7 ---------------------------------------> 1 8 ---------------------------------------> 2 9 ---------------------------------------> NC
If not work, invert the RJ45 connector
Mar 03, 2010 | Alcatel Newbridge MainStreet 3612...
No chain oil coming through
Remove the side cover, bar and chain. Clean the side oil port and any passages connected. Use compressed air to blow out the oiling passages in the drive end of the bar including the small ports that connect the chain guide slot to the larger holes in the bar. Run the motor for a short time without the bar and chain, there should be oil that oozes out of the side port. If not, then the pump, the filter in the oil tank, and the intervening oil line needs to be checked. When everything is back together, the far end of the bar should throw off a fine line of oil on a piece of cardboard after running for a little while. Hope this helps!
Feb 20, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I have a leak from the back of the refrig where the white water supply line goes into the yellow bracket. I can not get the house back into the yellow clamp.
That line , usually pops out when the fill tube is clogged with ice , due to a seeping water valve . If 2 screws hold this bracket , remove them and pull the fill tube out and defrost and reinstall . Use wd40 at an angle, to keep from getting into the line , to slip the line back into the bracket and replace the water valve ( the piece connected to the refrig where the wall water line connects to ) .
Oct 21, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Cannot get sound using dvi cable
DVI is digital VIDEO interface, you will need a seperate cable for audio
Jun 15, 2009 | HP w1907 LCD Monitor
NEED TO FIX FRONT BRAKE LINE METAL
In a pinch, I agree, use a compression fitting. But that is even harder than doing it the right way. After cutting the line, you have to have it perfectly round. By working with the already rusty metal, you are now fatiguing the metal. Then add on the compression, and added weight, and you get yourself a weak point.
The easiest way is to by the right length line or lines (It is far better to have more than less), the couplers (if needed), and any special adapters you may need (ie 3/16 standard flare to 1/4 bubble flare.) Take with you the ends and a section of line. The line is not that expensive ($7 for the longest.)
Start running the line, one section at a time, making sure to keep the ends on the end. When you need to make a bend, DO NOT make a tight bend that crimps the line. Discard the line if this happens. If you have a tool, use it. Other wise use you hand to make, gentle bends. Connect one end and connect the couplers, if used. When you get to the other side, wind the excess around a spiral. Secure with wire or existing retainers.
This is way safer than a compression fitting, and not all that hard. Remember to bleed the brakes
May 28, 2009 | 1984 Buick Regal
I have a 1994 Ford Aerostar that is leaking trans fluid from pinhole in metal tubing near radiator. Anyway I can plug leak?
is your line 5/16 or 3/8 dia. use small dia. tubing cutter. ( 10.00 15.00 at parts store ) cut your line
cut again to get rid of the cause of the leak. while at parts store also buy a compression fitting same size as lines. it will be comp union 2 ferrules two compression nuts put you nuts on the line first then you ferrules then insert your union in the middle of the two open ends then tighten the two compression nuts same time opposite directions
hope2help shack
Apr 16, 2009 | 1996 Ford Aerostar Extended
Dishwasher installation problem
I have had this problem in the past as well. They state that you have all the parts you need to install the dishwasher, however that is assuming that it is under ideal conditions. You will need an adapter to attach to the fill line to make it match the size on the diswasher. They usually only cost about $3.00.
Nov 09, 2007 | Kenmore 15129 Built-in Dishwasher
Alcatel Newbridge MainStreet 3600 Multiplexer Logo
99 people viewed this question
Top Alcatel Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
