Question about Fuji FinePix S2 Pro Digital Camera
Error message card not initialized. It's been formated, and new batteries installed. what is the next thing to try?
  • 17,970 Answers
Sounds like you pulled the card out while it was still uploading images to the computer, corrupting the card. So...a.- to try to recover the photos, you'll need photo recovery software, like digital photo rescue or others available via an internet search and...
b.- you'll need to put the card into the reader after you're done and reformat in FAT (not FAT32, not NTFS) so the card will be readable again in the S2pro.
What would happen is this: people would attach the card to the computer and delete using the computer. This can create a recycle bin on the drive. The next thing is that the card might be "unmounted," in that many people will just pull the memory card out of the reader and stick it into the camera without first unmounting the card.
This leave the card in an "open" state which the S2 Pro cannot properly read. The solutions:
1.- make sure there's no recycle bin on the card;
2.- plug it into your computer, and then properly unmount the drive using the taskbar, then pull the card out of the reader after you've been told it's safe to remove the card.
Since you describe a power issue as a possible initial cause, your final option is a new memory card. Also, only format in FAT format, since that's what the S2 Pro can see; not FAT32. You might also try formatting in another camera and then the S2 Pro.
Hope helps.
Posted on May 23, 2011
Testimonial: "right on the money. send me a bill. I'll remember you in the future. Thanks."
  • ZJ Limited
    ZJ Limited May 23, 2011
    Thank you for using Fixya.
Tip
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.<br /><br />We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.<br /> <br /> If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
on Feb 14, 2011 | Cameras
I have a finepix S602Z and when i turn it on it comes up as card error this happens on different cards any ideas on how to correct this please
I suggest you take the batteries out and wait two minutes and reinsert them. Making sure that they are inserted correctly. If this doesn't work, try replacing the batteries with new ones.
If you formatted the memory card using your computer, or deleted images using your computer, you now need to Format the card with the CAMERA. One of the camera menus will have a Format command.
This is what FujiFilmUSA.com has to say about the Card Error:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 14, 2011 | Fuji FinePix S602 Zoom Digital Camera
I have just installed a 4 GB Sandisk in my new Kodak Eash Share C195 camera and it keeps giving me an error message - "Memory card is protected, Reset switch on memory card" I saw only one switch...
Deb,
A couple of things you might want to try the little lock on the side of the memory card should be in the unlock position. If you are still getting the error message then shut off the camera and remove the battery and the memory card. Insert the battery after about ten seconds should and install the memory card then turn the camera back on. Format the card in the camera NEVER format the card in your computer, format the card over deleting single images. If this camera is new, new then you should have the instruction manual or may be called the owners manual look for formatting instructions, every digital camera has a format feature to clean the memory card. Now if all this still doesn't work you may need to update your camera software. My Canon Pro camera gave me a headache when I went from a 4 gig to an 8gig card it just wouldn't acknowledge I even had a card in the slot. However you may just need to hard boot it after switching the memory card to the unlock position. Don't forget to format the card. Robert
Dec 17, 2010 | Cameras
I have got a samsung mobile phone C3200 Monte Bar. When i want to write a new message,open inbox, or outbox i get the error initializing sms service. I tried to remove battery and sim card also.
Dec 08, 2010 | Pantech Matrix Cell Phone
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
Apr 12, 2010 | Canon Legria HF200 Flash Media Camcorder
Error Message
try to format the sd card from the camera and then check if it is usable,if not try another sd card.
Oct 11, 2009 | Panasonic HDC-SX5 DVD Camcorder
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Intializing Card Error Message
Just format your card once your problem will be solved
Jan 21, 2009 | Fuji FinePix A607 Digital Camera
Card Not Initialized!! Fuji FinePix 2600 Zoom Digital
Are you using the camera to format the card ? I had a similar problem with a 3V 16MB card in my Fuji MX1200. I used the "Format" capability, oddly located in the "Trashcan"/erase mode, but it "initialized"/formatted the card with no problems or error messages after that. Hopefully you have a similar format function on your camera. The URL I'm referencing here is for the MX-1200, but you may find your camera elsewhere on this excellent site (not mine).
Aug 25, 2008 | Fuji FinePix 2600 Zoom Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
606 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
