Question about Ryobi Garden
Ryobi bd4600 4" belt/6" disc
  • 8,197 Answers
You can get the manual on the link below.
http://dl.owneriq.net/2/29376206-744b-4024-a838-8e43f307520b.pdf
Posted on May 23, 2011
How do you adjust the belt tension on the Ryobi BE321 belt sander?
Usually there is no belt tensioner on by sanders. Only alignment adjuster. Must use exact size belt.
Jan 06, 2015 | Ryobi Tools & Hardware - Others
Where can I find a Manual for?
The manufacturer's website might have a pdf or similar in its support page.
Aug 21, 2014 | McFeelys Dayton Belt & Disc Sanders 2" X...
Ryobi belt and disc sander
It's only a month old. Take it back for a repair/replacement under warranty.
Jul 01, 2017 | Tools & Hardware - Others
Where to buy 55-3554-4 drive belt
Applied Industrial Technologies Brampton they also have several other location just google the name
May 05, 2012 | Ryobi Mastercraft Belt/disc Sander Belt...
Belt for ryobi belt sander cb76k
Cannot give a direct answer, since I don't know what country you are in (I'm in France). Try doing a Google search for "Toothed belt suppliers, (your city)". Try a Yellow Pages search for the same.
Shops selling toothed belts can nearly always find an equivalent, if you take the broken one to the shop.
Hope this helps.
Nov 25, 2011 | Ryobi Tools & Hardware - Others
I have a Ryobi BE-321 belt sander. The drive belt is strtipped. Are replacement belts still available?
Yes, you can purchase a new belt here:
http://www.ereplacementparts.com/ryobi-be321-belt-sander-parts-c-7931_7932_15013.html
Luke
Oct 27, 2010 | Tools & Hardware - Others
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Jan 08, 2009 | Tools & Hardware - Others
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Garden Logo
177 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
