Question about Pentax Optio A10 Digital Camera
Copy files from the built-in memory to sd memory card by using camera function?
I want to know how? because i saw the built-in memory is full.. but i can't delete it, because the pictures are very important.
Thanks.
  • 3 Answers
Go to playback menu, then down to copy function.
Posted on Aug 17, 2008
SOURCE:
I have taken the sd card out of the camera, downloaded to my computer and now the camera will not read the sd card? Please help
Hi John,
First, make sure you have the photos on the computer. Once you know they are - then you know you have a working copy of them.
The problem you're describing can be the result of MOVING the files - rather than COPYING the files. Moving is the process of moving the original files from the card and putting them on the PC - while copying leaves the original files on the card and creates a copy on the PC. If you MOVED them then you shouldn't expect to see the original files on the card any longer.
If you copied them and the card no longer shows them or if you copied or moved them and the card is no longer visible the card may have been removed before it completed the file move / copy operation. You should only remove a card / usb drive / similar device when a message pops up saying it is safe to do so.
If: 1) there are no files visible, 2) the card can no longer be read or 3) your computer says the card needs to be formatted first - you may need to do that in an attempt to make the card useable again. If you do not have a copy of the files on your PC - try to copy them to another PC before formatting the card. If you can not get copies of the pictures / files on a 2nd PC, the files / pictures on the card are likely lost. You may find utilities than can restore them however (see link below)
recover pictures from memory card Google Search
Good memory card management includes 1) copying files from memory cards, 2) verifying that they have transferred successfully *and* finally 3) formatting the memory card *in* the camera; *not* the PC. Most cameras offer options to format cards - which is superior to simply deleting files or formatting in a PC. The camera tends to set the card up for its own use - rather than for a PC's use. Formatting the card in the camera can introduce subtle differences that make it worthwhile to do.
Not as much a big deal nowadays - but older devices, cameras, etc. can read / write only to "straight" SD cards. Today, there are SDHC and SDXC types. Make *sure* that you're using the type card your camera expects. Using an SDHC or SDXC card can have unpredictable results when used in devices that expect the older, "straight" SD (no "HC" and no "XC" suffix) type cards. More details about card types can be found linked below:
Back to Basics The Difference Between SD SDHC SDXC and Which is Best for...
Jun 17, 2015 | Bell & Howell DNV16HDZ Full HD Rogue Night...
Camera will not allow me to "copy" photos to transfer from internal memory to SD card?
You may be able to connect the camera to a computer and access the picture files that way. Also make sure the SD card isn't close to full.
Jan 01, 2014 | Panasonic Lumix DMC-ZS3 Digital Camera
Built in memory
I thought I already answered this one yesterday. But here it comes again. In the manual on page 73:
Copy to Card (Copy internal memory to memory card)
Use this setting to copy the files stored in the internal memory to the memory card.
  1. Select the Copy to memory card setting from the Setup menu as described previously.
  2. Use the Up/Down navigation buttons to select Yes or No. Then press the (Func Ok) button to confirm.
Don't forget to format the memory card first. do it in the camera and not in a FC or MAC. Be sure you are using the right memory card. You can use a SD or a SDHC card. Don't try a SDXC card, because it is to big and the camera software can't handle these cards.
Nov 11, 2013 | General Electric A1250 Digital Camera
My images are on the camera's memory and not on the SD card. I want to upload them to my iPad with my card reader. How can I transfer them from the camera's memory to the card?
You can use the Copy command in the Playback menu to copy your images from the internal memory to the SD card. Full details are in the "Copying Files" section of the manual (page 95 in my copy). If you need a manual, you may download a copy here.
Apr 21, 2012 | Pentax Optio S4 Digital Camera
I have a DMC-FS9. The 4GB card is full. Have mislaid my instruction manual and although I have the pictures on a CD now I can't delete the photos. Also the in built memory is full. Would appreciate...
Please refer to page 22 of this manual to see the instructions about deleting all the pictures at once.
http://cdn.cnetcontent.com/60/18/6018a504-e839-4328-a3f0-b59e9d319a08.pdf
If it does not work then please let me know and I will help you format the internal memory and the card.
PS: Bad rating = No further help!
Aug 03, 2011 | Cameras
I have a camcorder Panasonic SDR-T55 and want to copy my pictures from built in memory into sd card but I don't know . Please help
You may not have that option.Most camcorders give you the option to either record to the built in memory or the SD card Flash Memory.The option to copy from the internal to SD card is device option. You can use USB, AV , cables to convert files to DVD or other formats to copy to Flash Media or DVD/ VCD/DVD RAM.Good Luck.
Jul 29, 2011 | Panasonic Video Cameras
When I turn on camera to take picture, it says memory full. How do I clear this?
tego34:
From the user manual for this camera (click here) page 247, it says "Memory is full. If you want to record more files, delete files that you no longer need" and references page 161 in the same manual.
On page 161, it gives you the directions for deleting un-needed files (pictures).
I would suggest transferring all of your pictures to a computer using Picasa and deleting the pictures that you've taken from the camera.
If you're using the memory that is built-in to the camera, it is much too small to hold many pictures. You should buy a 2GB SD card that meets the specifications in the user manual page 180.
Feb 17, 2011 | Casio EXILIM ZOOM EX-Z60 Digital Camera
MY CELL PHONE MEMORY IS FULL I CANT SEND PIC TEXT OR TAKE PICS I HAVE NO CHIP IN MY PHONE YET JUST THE BUILT IN PHONE MEMORY HOW CAN I ERASE THE PHONE MEMORY SO I CAN TAKE PICS
two solutions 1. go to media chose a picture you want to delete, and if possible chose delete/basket sign, if not possible chose options --> delete picture 2. go to settings, mediasettings, photos, erase memory
Dec 15, 2010 | Cell Phones
Hi, I took some great pictures recently before i realised my kids had removed the SD card, the camera came with a cradle to charge the battery and to download the pictures, this cradle is now broken, is it...
You can't copy individual files, but you can copy all files from internal memory to an SD card.
  1. Load the card to which you want to copy.
  2. Turn on the camera, enter the Play mode, and press MENU.
  3. Select "Copy" and press right-arrow.
  4. Use up/down-arrows to select "Built in -> Card" and press SET.
For full details, refer to page 203 of the manual.
Aug 31, 2010 | Casio Exilim EX-Z1200 Digital Camera
DMC-FX55 memory problem
Press menu/set...playback menu....select "copy" Make the choice to copy the internal memory to the card and select "yes".
Jun 30, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Pentax Optio A10 Digital Camera Logo
188 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
