Question about HP Photosmart E337 Digital Camera
NEED TO SET TIME AND DATE - HP Photosmart E337 Digital Camera
  • lakegrl49 May 23, 2011
    I am not clear if we are on the same page.I need the date and time printed on the pictures, as I need to use them for evidence. Will the pictures have the date and time printed on them?
    INFO WAS ON PAGE 5, NOT 6.
  • 2,574 Answers
Download this manual for HP Photosmart E337 >>start download
Go to page #6 Set time and date.
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Posted on May 23, 2011
  • 17,970 Answers
Accurately setting the date and time will help you locate images once you have transferred them to your computer, and will ensure that images are accurately marked if you use the date and time imprint feature. See Date & Time Imprint under "Using the Picture Capture Menu" on page 11.
1. Use to adjust the highlighted value.
2. Use to move to the other selections and repeat Step 1 until the date and time are set correctly.
3. Press when the date, time, and format settings are correct, then press again to confirm.
To change the date and time later, use the Camera Setup Menu (see "Using the Camera Setup Menu" on page 25).
All page mentioned are refer at user manual from HP site.
Hope this helps.
  • ZJ Limited
    ZJ Limited May 23, 2011
    The Picture Capture Menu allows you to adjust camera settings that affect the characteristics of the pictures you capture.
    1. Slide "camera" , "play" to "camera", then press "MENU/OK".
    2. Use "UP" or "DONW" to highlight an option, then press "MENU/OK" to display the option's menu.
    3. Use "UP" or "DONW" to highlight a setting, then press "MENU/OK" to change the setting or press "RETURN" to exit without changing the setting.
    4. To exit the menu, hold down "RETURN" until the menu disappears.
    For information about an option, use "UP" or "DONW" to highlight "? Help..." in the option's menu, then press "MENU/OK".
    Unless otherwise noted, the setting remains in effect until you turn off the camera. The next time you turn on the camera, the settings reset to their defaults.
    Good luck.
Setting time, date on power book g4
I'm taking it that you are running system 10 so go to system preferences under the apple menu, then go to date and time under System. Go to time zone and allow the time zone to be set automatically and then go to date and time and set the date and time automatically. If you want to set the date yourself you can uncheck the set date and time automatically and then select the date and then the time using the up and down arrows. Hope this helps.
Dec 06, 2012 | Computers & Internet
My Nokia E5 is set by default to daylight saving mode, but it is canceled this year in Egypt, so I need to uncheck the auto adjust daylight saving but I cannot.
1 Press Menu or and select Settings.
2 Select Date & Time and choose from the
list below:
Set date - You can enter the current date.
Date format - You can set the date format.
(YYYY/MM/DD, DD/MM/YYYY, MM/DD/YYYY)
Set time - You can enter the current time.
Time format - You can set the time format to
either 24 hours or 12 hours.
Auto update - Select OFF, the phone will NOT
automatically update the date and time.
May 22, 2011 | Nokia E5 Cell Phone
How to set time on your camera so that when you print your photo's, it shows the date
The date/time setting process may be slightly different on different camera. Which camera do you have ? Nevertheless, you first need to set the date/time on your camera. And when you print, say using PictBridge, you need to set the DPOF date setting at WITH DATE. And you need to use a printer that supports date printing.
Feb 18, 2011 | DSC Cameras
How to set date and time in Samsung Corby 3650? Ihave recently purchased the phone but it is showing some other time and the date set is in 2009. Kindly help in this regard.
Go to settings---Date and time--->set your time and date and your time zone.And you can activate automatic update after that.So you no need to set the time again and again
Oct 14, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Cannot set date & time on Panafax UF-895
To set the date and time, do the following:
  1. Press function 7
  2. Press 1
  3. Press SET
  4. Enter date and time using 2 digits for month (sept 09)
  5. Enter 2 digits for Date
  6. Enter 4 digits for year
  7. Enter 4 digits for time (military time ex: 3pm 1500)
  8. Press SET
  9. Press STOP
The date and time are now set. Best of luck.
Greg
Aug 24, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Motorola RAZR V3i Cellular Phone set the time/date
the best info that i can provide is to download ur user manual.
after that search for time and date in the PDF.
quote form nanual:
time & date
Your phone uses the time and date for the
Datebook.
To synchronize the time and date with
the network: Press a >wSettings
> Initial Setup > Time and Date > Autoupdate
> On.
To manually set the time and date, turn off
Autoupdate, then: Press a >wSettings
> Initial Setup > Time and Date > Time and Date.
manual
http://www.motorola.com/mdirect/manuals/V3i_9504A48O.pdf
plz give
Mar 25, 2009 | Motorola Cell Phones
Need to set an Ultronic clock
Press the time (current time - numbers) to get to the date mode. Then hold-press "SET" to set it.
Feb 19, 2009 | RIM BlackBerry Pearl 8100
Rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
Jan 03, 2009 | Watches
Ativa at-p3000 adding machine....no user manual or way to set ate and time
To set the time: Press the date/time button (next to the feed button) to make the time appear on the display. Then press and hold the "Time Set" button (the "=" button) until the first digit of the time setting begins to flash. Then just enter the current time with the keypad (3:30 is 0-3-3-0) and use the "AM-PM" key (the "x" button) to toggle am/pm. After you have the time entered, press and release the "Time Set" (=) again to set the new time.
To set the correct date: Press the date/time button (next to the feed button) to make the date appear on the display rather than the time. Then press and hold the "Time Set" button (the "=" button) until the first digit of the date begins to flash. Do the same as before to set the new date. Don't forget to press the Time Set button after you set the date or it will not record the change.
If for some reason you need to reset your calculator, turn it over and stick a pencil into the reset hole next to the battery compartment. That will reset everything.
Dec 14, 2008 | Computers & Internet
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
HP Photosmart E337 Digital Camera Logo
43 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
