Question about Microsoft Windows XP Home Edition
Running out of space on C drive
My Intel Pentium 4CPU Desktop computer has three drives in the hard drive: C drive has 5GB and E drive 20.5 GB; the E drive is set as active and has most of the program softwares. D drive is 54.5GB and used to store data files. I need more space on the C drive to get softwares update and install Adobe Reader, etc.
How do I combine the C and E drives into a new (or existing) C drive?
If it cannot be done, can I format the hard drive and use "a copy of a copy" the Window XP Home Edition software to re-install the window operating? The prodcut key for the XP Home Edition is on the label in the back of the computer. The current operating sytem is Window XP Media Center Edition version 2002 for which I do not have the software CD.
  • 1 more comment
  • viet9999 Aug 16, 2008
    thank for suggestion.
    The PowerQuest(R) PartitionMagic(R) Version 8.0 (45 days trail) ReadMe File states
    "Be aware that there is no undo (after clicking Apply) if you
    merge two FAT or FAT32 partitions. You must be particularly
    careful not to merge two primary partitions that include
    operating systems, as your computer will not be bootable if
    you do."
    Are the above software say that if I merge E into C drive (appears the operating system software is in both E and C drives in my computer) and my computer will not boot up?
    Please advise and Thank You
  • viet9999 Aug 17, 2008
    Thank You for advice on comparing the C & D drives into one C drive and it works.
    Another follow-up hard drive problem:
    When I try to install Adobe Reader 9, it shows error massage "Error 1327.Invalid I:\". Please let me know how to fix this problem.
    Thanks
    I fixed the problem with installing Adobe Reader 9 by using the following solution posted in the past on this web site as follows:
    Hit Start, Run and type Regedit
    Find the following HKEY_CURRENT_USER\Software\Microsoft\Windows| CurrentVersion\ Explorer\User Shell Folders
    In the right pane - see if these is any entries which has an F or any other alphabelts not C (your OP folder) modify data to C:\
  • 59 Answers
Hi, you can merge your E drive to your C drive. You just need to download a free hard disk partitioning software like AOMEI Partition Assistant. Step-by-step tutorial to follow: http://www.disk-partition.com/help/merge-partition.html
Posted on Feb 05, 2013
    Champion:
  • 214 Answers
Hi, its possible to merge two partitions.
down load a partition changing software like partition magic and install it. Have a look at the help available and and go for merge partition.
thank you
Posted on Aug 16, 2008
  • Rabby V V
    Rabby V V Aug 17, 2008
    hi, thanks for the response
    actually you want to incease the size of the C:\ drive, is that right?
    then go for RESIZE and select C:\, give the new size and follow the wizard.
    this will work without any problem
    thank you
If I have two exact same brand and model of cpu's,can I use them in tandem together as if it was one?
this is time to purchase new stronger computer with minimal 2 core and 2gb ram and 256 gb of hdd.
for os I sugest win7 32/64 or recent. is not necessarily a new U can buy used computer.
Jul 11, 2014 | IBM Netvista Intel Pentium 4 2.4GHz /...
Says my system is not suported
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE Windows
  • OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
  • CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
  • OS: OS X 10.4.11
  • CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE Windows
  • CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
  • OS: OS X 10.5.5 or greater
  • CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mar 11, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
How much i can upgrade my d530 ultra slim desktop RAM and HDD
You can install up to a max 2 GB RAM and can add a 2nd hard disk
See the following Specs for your computer.
dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
  • Product Form Factor Ultra-slim desktop
  • Built-in Devices Speaker
  • Width 12.4 in
  • Depth 13.1 in
  • Height 2.8 in
  • Weight 15.4 lbs
  • Color Silver
Processor
  • Type Intel Pentium 4 2.8 GHz
  • Installed Qty 1.0
  • Max processors supported 1.0
Cache Memory
  • Type L2 cache
  • Installed Size 512.0 KB
  • Cache Per Processor 512 KB
Mainboard
  • Chipset type Intel 865G
  • Data bus speed 533.0 MHz
RAM
  • Installed Size 256.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM
  • Memory Speed 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor DIMM 184-pin
  • Upgrade Rule Max 2 x 1 GB module
Storage Controller
  • Type 1.0 x IDE - Integrated - PCI
  • Controller interface type ATA-100
Storage Controller (2nd)
  • Type 1 x Serial ATA - Integrated
  • (2nd) storage controller interface type Serial ATA-150
Storage
  • Floppy drive type None
  • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
  • Hard Drive (2nd) None x None
Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Video card
the requirements are
FOR WINDOWS XP
  • Windows XP (Service Pack 2)
  • 2.0 GHz P4 processor or equivalent
  • 1 GB RAM
  • At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
  • 128 MB Video Card with support for Pixel Shader 2.0
FOR WINDOWS VISTA
  • Windows Vista (Service Pack 1)
  • 2.4 GHz P4 processor or equivalent
  • 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least:
  • Intel Integrated Chipset, GMA X3000 or above.
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
So what does your computer have?
Jun 02, 2009 | Microsoft Windows XP Home Edition
Partision prblem
This is because an 80GB hard drive only has 75GB inside it will not be exact because of the way hard drive manufacturers compute the size. 80GB by name but only 75GB in real hard drive space. much like a if you have a flash drive or a portable uSB you will notice this also.
Dec 27, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Bigger hard drive
I'm not sure if the motherboard supports SATA drives, so your best bet is getting any IDE (ATA) hard drive. It's up to you which kind you want. I've always been partial to Western Digital and Seagate.
If you are running Windows XP then you shouldn't have a problem with having a larger hard drive, I know Windows 2000 had some issues with them that required registery editing.
Dec 11, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
Hard Drives
You should be able to see the drive under either my computer in windows explorer.
Jun 14, 2008 | Gateway E-2000 Deluxe PC Desktop
Upgrading to Windows XPx64
The answer is no because your motherboard still only supports 32 bit drivers. Read On.
Here's what you need to use Windows XP Professional x64 Edition
Important: Windows XP Professional x64 Edition cannot be successfully installed on x86 (32-bit) systems or 64-bit Intel Itanium–based systems. 32-bit device drivers are not supported on Windows XP Professional x64 Edition.
• Computer with a supported processor: AMD Athlon 64, AMD Opteron, Intel Xeon with Intel EM64T support, Intel Pentium 4 with Intel EM64T support
• 256 megabytes (MB) of RAM or higher recommended
• 1.5 gigabytes (GB) of available hard-disk space (additional space may be required if installing over a network)
• CD-ROM or DVD drive
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• Keyboard, Microsoft Mouse, Microsoft IntelliMouse, or compatible pointing device
arrow_px_up.gifTop of page Additional items or services required to use certain Windows XP features • 28.8-Kbps modem or fax modem and service provider required for Internet access (service provider may charge a fee)
• Sound requires a sound card and speakers (USB speakers require a computer with USB support) or headphones
• Remote Assistance requires that both parties be running Windows XP and be connected over a network
• Remote Desktop requires a computer running Windows 95 or later and the two computers must be connected over a network
• DVD video playback requires a DVD drive and DVD decoder card or DVD decoder software and 8 MB of video RAM
• Windows Movie Maker video capture feature requires an appropriate digital or analog video capture device and 400-MHz or faster processor for digital video camera capture
May 09, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Microsoft Windows XP Home Edition Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
