Question about Canon imageRUNNER iR C4080 Color Copier
I have a canon 4080 -when you start it,power up,then fan goes on-says right cover open -paper jam-took everything out,cleaned everything,no paper-1 tech rep said it is sensor #26 on copier monitor-how can I fix? anything to do with right side drawer?Please let me know,JD
  • 1 more comment
  • joedevona May 24, 2011
    I put other parts in where paper feeds from drawers on the top 2 ,I think where the sensor is supposed to be---No good,still crapping out and right door open,paper jam-another tech told me the same thing u did-any other suggestions,Im really in a bind here,JD
  • joedevona May 25, 2011
    Hi I did what you told me regarding the blowout and all,still N/G-am still playing around with it-Ive heard the next thing to check is the board,does that sound right? let me know ,JD Thanks!!
    Turns out the plug inside attached to right side tray that slides in was bent,so no connection-drove me crazy,thanks for your help,JD
  • 5,370 Answers
Yes its quite possible that right side cover sensor is either stuck up or got broken so the copier is not sensing that cover closed and its indicating you to close the cover.Open the right cover and see on that cover you will see some extended plastic parts.That plastic parts trigger the sensor in the copier when you close it.The sensor will be in the copier side and extended plastic parts will be on right cover side.So That plastic depress the sensor in the copier when you close the cover.So check where this plastic enters the copier.There will be the sensor.---------Many a times sensor will be just getting stuck up and needs to be re aligned .But some times sensor gets broken, so in that case it needs to be replaced.You can try pressing that sensor with a tooth pick also.The sensor just needs to be depressed.Once the sensor is depressed down the cover will be detected as closed.Some times there are more then one sensors that get depressed when cover gets closed.------------ Try this.This should help.Thanks.Helpmech.
Posted on May 23, 2011
  • raj somaiya May 24, 2011
    Till the sensor is not in its place, the machine will not detect door closed.Open the drawer door and blow air blower on the inner side of the machine when door drawer closes.Blow air for few minutes, may be that will blow the dust or any other obstacle causing the sensor to block.------
    this should help.thanks.helpmech.
  • raj somaiya May 25, 2011
    The sensor gets power from board.The function of sensor is controlled by board.But getting the board checked is not easy task.You will need good testing tools and even testing skills.Most probably, in your case it seems that sensor is got cracked or bent and so its missing.Get the sensor replaced by local printer / copier repair techs.Because getting to the board means disassembly of the copier.Board is a costly part and has several components on it.If the components fail or any part gets short on board, then it will be costly repair.Its advisable to get sensor checked and replaced by local printer/ copier repair tech.-------- This should solve the issue.Thanks.Helpmech.
Canon icd320 paper keeps jamming before it goes into the imager. how to fix
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 30, 2014 | Canon Office Equipment & Supplies
Paper jam and no paper jam
Probably paper never being picked up and not feeding out of cassette which explains why you see a jam indicated but cannot find a jammed paper. Probably time to rebuild the cassettes.
Aug 28, 2012 | Canon iR 2016i Black and White Copier
Paper jam in canon printer mx432
I took Ekse suggestion to start off with by turning off the printer; opening the front cover and removing the ink cartridges. Behind where the color cartridge goes is a light blue wheel. I took a letter opener and gently tried to move it. It moved and after a few turns it loosened the paper and I was able to gently removed the whole sheet of paper. I'm by far a techy but have been known to take care of paper jams. This little machine had me baffled because the back was of no use like other machines.
Jul 05, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Paper Jam and i do not have one. Help
Hello sir; On the paper exit unit there have a paper exit senser got to be stuck or out of track. loose it or put it back in right position.
May 18, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Paper light flashing
What worked for me was to clean the drumunit; take the toner out of the drum unit and clean between the plastic housing and the drum. Dust heaps up and presumably makes the toner rotate more difficult.
I just used a piece of folded paper and blew the rest out..
Bas
Aug 14, 2008 | Office Equipment & Supplies
Hp Officejet 6310 All-in-one paper jam
Here's a video that shows how to clear a jam on this printer.
Apr 08, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon PIXMA MP160 showing paper jam, but none
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
MF-8170C REC. PAPER JAM and Open Cover
Get a thick piece of paper and feed it in to the printer following the paper path the best you can until you get the piece of paper you can't see out of it.
Oct 16, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
Canon imageRUNNER iR C4080 Color Copier Logo
77 people viewed this question
old marine
old marine
