Question about Garden
I have a Paramount Shear King electric model 5404-01. On one edge of the half shield there was a sharp piece of medal that cut the cord when too much was fed out.That "cutter" rusted out. Where can I get another one?
punker0204
  • 54 Answers
SOURCE: Using the cutter
you want to print borderless on a cutsheet media? you just have to select and 'cheat' the printer in the printer properties, in there choose roll on the paper source option then enable the cutter and choose double cut on printer's set-up menu on the panel, then it'll cut before and after the printing to make it borderless from top to bottom and from edge to edge. just be sure that the cutsheet media is long enough so that the printer can still hold the media as it finishes the printing or else it'll be a waste, cause the printer wont finish the image. and take note that the epson sp9600 has a limitation in printing borderless, it'll only print borderless on (12", 17", 24", 36:, and 44") media size only i think there's also 14". trust me it'll work, ive done it! :P
Posted on Sep 27, 2007
ozztech
  • 285 Answers
SOURCE: hi i have problem with my zebra m4plus cuter the
select the TEAR OFF mode on the same seting that you have the Cutter.
Posted on Nov 13, 2010
BCAS1298
  • 3092 Answers
SOURCE: I can not close my front door. it appear that the
Try to hold the door handle in the open position while you pull on the door latch, the medal piece, should open so that the door will shut close.
Posted on Dec 01, 2010
  • 21 Answers
SOURCE: cutters do not activate when
make sure sensor switch is free and clear. unplug first before cleaning out. You will see little swith if you look inside where paper is fed in. GL
Posted on Dec 22, 2010
  • 1788 Answers
SOURCE: where can i buy an electrical cord and the medal
Call Brother at 1-877-276-8437 and order it direct from them, or go www.sewingpartsonline.com and buy from them, the foot control costs $29.99 and the power cord costs, $13.99 from Sewing Parts, I don't know what Brother's price is, but you can compare. Happy New Year
Posted on Jan 03, 2011
How do I cut up a large mirror?
Essentially the same as cutting glass. Get a glass cutter with a new sharp wheel. Practice on a piece of scrap glass the touch. Firm but not too heavy then make a smooth stroke along a straight edge to guide your cut.
Put a t' thick board under the line to be broken with the board to the left of your intended cut then make a push down on the glass to the right of the break line. If you have made a good continuous scribe line in the glass completely along your cut line it will snap cleanly into your desired two pieces. Repeat until you have the sizes you want. It will only break in straight lines in this method.
Us a torch to burn the edge corners to keep them from cutting you. Just heat it long enough to round the sharp edge.
Jul 02, 2014 | Home
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
My toutliner cutting too sharp
Adjust your blade. Remove it from the clipper, and then loosen (don't remove) the two screws that hold the blade and cutting edge together. Use a FLAT surface, like a ceramic sink top or flat piece of tile, and push the cutting edge down and angle the blade with the cutting edge facing the flat surface down to about a 30 to 35 degree angle. Use your thumb to hold in place until you can retighten the screws. Under a light, inspect to see if it is level (it will be noticeable if it isn't) or oil the blade and touch it to a clean dry piece of paper. If it is level, replace the blade on the trimmer, and edge your beard. It should be better than brand new. This also works when it doesnt seem like the blade is cutting sharp anymore. ALWAYS make sure the cutting edge is lower than the blade or you WILL CUT YOURSELF or YOUR CLIENT!
Mar 29, 2014 | Andis T-Outliner Hair Trimmer
DP80F FAX WILL NOT FEED ONE PAGE AT A TIME. IT WILL TAKE 1 PAGE , 5 PAGES , 2 PAGES . HOW DO I FIX THIS MACHINE TO FEED ONE PAGE AT A TIME
Potential solution: When putting in several sheets of paper, grab the sheets by one end, and fan the papers (spread them) at the other end. Reverse your grip and do the same thing to the other end.
Reason: paper is cut by a shear. If the blade of the shear is not perfectly sharp, it crushes fibers into the edges of the adjoining sheets. This causes the sheets to misfeed in the random way you describe. Ruffling the paper before putting it into the printer separates the pages so they will feed properly.
Nov 07, 2011 | Toshiba DP80F Printer
Is there a way to put the deflector shield in an up position when the mower is not being used?
Find a bungee cord at walmart, this is a heavy stretchable cord with metal hooks on the end.
drill a hole through the outside edge of the shield.
when you are not mowing, put one of the hooks through the drilled hole and wrap the other end of the bungee cord around the grip handle or the steering wheel.
do not hang the bungee cord anywhere on the mower when it is in use as you will somehow turn it into a hurtling projectile of death or injury
there you go!
Mar 01, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I can not close my front door. it appear that the half circle locking part of the door, which is located on the side of the door that opens, has a piece of medal that is blocking the door from closing. I...
Dec 01, 2010 | 2001 GMC Denali
Catalytic Converter 2002 ford taurus does the engine have to come out or just the axles? what is the best way to replace the Catalytic Converter? I have remove the heat shield and disconnected the pipe,...
SECTION 309-00: Exhaust System 2002 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Dual Converter Y-Pipe -3.0L (2V)
Special Tool(s) s2h~us~en~file=st2363a.gif~gen~ref.gif 3 Bar Engine Support
303-290A s2h~us~en~file=st1595a.gif~gen~ref.gif Engine Lifting Brackets (3.0L 2V)
303-050 (T70P-6000) or equivalent Removal
  1. Disconnect the negative battery cable. For additional information, refer to Section 414-01 .
  1. Remove the bolts and engine roll restrictor.
  1. Remove the bolt, ground strap, and nut.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the splash shield and the air deflector.
  1. Disconnect the catalyst monitor sensor (CMS) electrical connectors.
  1. Remove the nut and position the heat shield out of the way.
  1. Remove the nut.
  1. Remove the nut.
  1. NOTE: Support the exhaust with mechanic's wire.
    Remove the nuts and disconnect the three-way catalytic converter from the dual converter Y-pipe.
  1. Lower the vehicle.
  1. Remove the nuts.
  1. Remove the bolt.
  1. Using the special tools, raise the front of the engine.
  1. Raise the vehicle.
  1. Remove the bolt.
  1. s2h~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The sharp edges on the converter can cut the CV joint boot. Make sure to protect the half-shaft boot with a suitable covering before removing the converter assembly.
    Remove the dual Y-pipe converter assembly.
  1. Remove the gaskets and, if necessary, the catalyst monitor sensors (CMS).
    • Discard the gaskets.
Nov 03, 2010 | 2002 Ford Taurus
Not getting clean/sharp cuts
the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
Aug 12, 2009 | Fiskars Brands Fiskars 12" Portable Paper...
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Garden Logo
311 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
