Question about Kenmore 64814 / 64812 Top Freezer Refrigerator
Condensation/water is leaking inside the fridge below the freezer
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 24, 2011
Leaking please help. I need to order a new one that is 120v 60hz 15w s-86
My experience if I understand when you say "Leaking" Is that into the inside bottom of fridge?>
If so on auto-defrost(frostfree) frdge. the tube in back outside &attached to the freezer is cloged and wont allow condensation to disperse into the pan below therefor it leakes to the inside instead. Try unclogging by pouring Verry Hot water into back of freezer{inside}.
Apr 13, 2011 | Refrigerators
GD5RHAXNQ00 LEAKING?
There are several causis from water leaking from the back of the fridge did you check is not condensation? In case you will need to lower fridge temperature
Feb 24, 2008 | Whirlpool GS6NBEXR Side by Side...
It is leaking water out of the bottom. It does not appear to be coming from inside the fridge or freezer. It does start on the bottom on the freezer side.
Without seeing your refrigerator I can only imagine that you have a drain pan leak below refrigerator, defrost condensate drain line loose or missing the drain pan, frozen over drain opening inside rear wall of freezer or the defrost condensate line is blocked somewhere along its route to the condensate collection tray below refrigerator.
Apr 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
Why is water is pooling at bottom of the fridge
WATER LEAKING FROM REFRIGERATOR OR INSIDE THE FREEZER OR FRESH FOOD SECTION
You have a blockage in your condensate defrost line or the pipe that fill the tray below the refrigerator is missing the condensate collector pan that uses the heat from the fan to evaporate the condensate back into the air inside your home.
Jan 05, 2010 | Fisher and Paykel Refrigerators
Frigidaire fridge leaks where ice maker is on
Your leaking problem gives two possibilities. The water control valve for the ice maker side is defective and while shut off the water will continue to slowly flow and leak into the freezer compartment. The other possibility id the condensate defrost drain is blocked and frozen over behind the rear panel of the freezer and at the bottom of th coils. I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 23, 2009 | Frigidaire FRS26R4A Side by Side...
Water leakage thru the freezer door - GE side by side fridge
I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look more simple. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge left a puddle of water in front of the freezer half, where could it be coming from?
I am going to assume you have a defrost condensate blockage in the rear of the freezer and behind the rear panel where the evaporator dreains condensate after each defros. Please correct me if I am wrong.
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator2.gif to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 27, 2009 | Kenmore Refrigerators
Top freezer leaks water into lower fridge on our sears kenmore #70267990
The answer to finding the cause of the leak is where we need to begin. Most start in the freezer section behind the rear panel where the defrost condensate is drained during defrost. Sometimes the drain hole freezes over and the water drains down into the freezer creating a large area of frozen water. Other times i happens as the water leaves the drain in the freezer and follows its path to the pan below your refrigerator to re evaporate into the air inside your home. If leaking inside the fresh food compartment then the cup behind the control panel may be over flowing and leaking down the back wall of the refrigerator and will need to be taken apart and cleaned to allow the water to continue down to the pan below the refrigerator. Sludge and dust or even ice may be blocking this line. Below is a link to a page that may help you resolve and fix this. If you have more questions feel free to let me know. appliancepartsse@yahoo.com Thanks, Sea Breeze
click link below
Aug 26, 2009 | Kenmore Refrigerators
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore 64814 / 64812 Top Freezer Refrigerator Logo
69 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
