Question about Dishwashers
Baumatic bdi631 filters blocked and overflowed and leaked, blockage cleared and dwasher drained but now 2 flashing programme lights and unable to choose a cycle! help!!!
COXY
  • 76 Answers
SOURCE: Baumatic BHD 5
Is the water draining out of the machine? if not does it drain when you lower the pipe to the floor, if it does you need a new pump, if it doesn't you have a blockage.
Posted on Nov 27, 2007
SOURCE: Dishwasher not draining
Hi James:
What a coincidence. I am having same issue in my GE washer and I called a handyman. He came, checked through to make sure there is no blockages and concluded it is the pump. He said it is going to cost 350-400 and recommended I buy a new one instead.
Rav
Posted on Jan 26, 2008
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Posted on Jun 05, 2008
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
I have a Baumatic BDI631 integrated dishwasher which has started making a strange noise when the water is coming out. It is washing fine but makes a buzzing noise when discharging the water which soun
It sounds like something's trapped in the pump touching the impeller. Drain the machine, isolate the electrics and see if you can access the pump, you may find a piece of debris or small article in the pipework.
Jan 05, 2015 | Baumatic Dishwashers
GVA dishwasher overflow light wont stop flashing
Have you tried unplugging the dishwasher power cord from the outlet, waiting 30 seconds and plugging it back in?
Nov 23, 2013 | Dishwashers
LG WM210HW doesn't fully drain
Pull the drain boot that runs from the tub to the pump and check it for blockage. Post the results back to me.
Feb 03, 2013 | Washing Machines
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
My Hotpoint Ultima Washing machine - When I switch it on all the lights keep flashing and I can't get rid of them !! When the machine then starts the cycle it still flashes but then stops half way and says...
I would advise you to check the drain outlet hose for a possible blockage, or the pump itself could be blocked or faulty.
Drain any surplus water in to a bucket or similar before removing hose or pump.
Also try resetting washer if there is a reset button, hold it in for at least 3 seconds, this should clear any programme held in the memory.
Hope this helps.
Feb 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
Panasonic inverter console is leaking water
The drain outlet is blocked on the outside of the unit. Blow into it to clear blockage. Also check that the air filter on the inside of the unit is clean. If dirty it prevents good airflow over the coil causing it to ice up and overflow past the drainpan.
Nov 17, 2009 | Heating & Cooling
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
396 people viewed this question
Top Dishwashers Experts
Owen Barnes
