Question about Lexmark Optra SC 1275 Laser Printer
Printer message reads error 13
Hello there.
I just bought a second hand Lexmark SC 1275. It did work fine the first couple of pages but now it reads error 13 when i turn it on. It actually read storing 13 with translates to error. Any one who can help me?
Thanks
Rob Steentjes
  • 412 Answers
Error: 927 Service Fan Stalled
Check the main exhaust fan first. All models of these printers have a main exhaust fan. The main exhaust fan is located on the top of the printer, on the rear left side.
Make sure nothing has fallen down into the main exhaust fan that could be blocking it. There are vent slots/holes in the top cover of the fan, on the left-hand side. Look through these vents/holes.
If there is an item stuck there, see if you can remove it. If not, you will probably need to have a technician remove the top cover unit and extract the jammed item from the fan.
If nothing appears to be blocking the exhaust fan, power off the printer and let it sit powered off for at least a minute.
While the printer is turned off, check to see how it is plugged into the wall. It should be plugged directly into a wall outlet and not through any sort of surge device or power strip. (Power strips and uninterrupted power supplies can cause a low amperage problem in your printer, which could trigger a 927 error.) Even if it has worked on this surge device for months, try connecting the printer directly to the wall. If the printer is already plugged directly into a wall outlet, try it at a different wall outlet.
When the printer has been off for more than a minute, power it on and see if the 927 error returns.
If the 927 error does not return, try printing again. If the printer works as expected, continue using it as you were doing before the error arose. The 927 error may have been just an isolated incident. However, keep an eye on it for the next couple of days to see if the error returns.
If the 927 Fan Stall error continues to return when you power on the printer or when you try to print, the printer will probably require service.
If you are a technician working on a printer that has ONLY one fan installed, check the cable connecting the main fan to the engine/system board. Make sure the connections at the ends have not come loose and that the cable itself is not damaged. The parts that are most likely to need replacing are the main exhaust fan or the printer's engine/system board.
Some printer models also have a second auxiliary cooling fan, sometimes called the cartridge cooling fan. Printers that have this fan are the Optra T614, T616, the Lexmark T622, the T63x series (630, 632, 634) and some models of the Optra S 2420, 2450, 2455, and Se 3455. Note: The second exhaust fan was eliminated on some later models of these S series printers. The auxiliary cooling fan is located on the back of the printer, on the right-hand side.
Check the fan as you checked the main exhaust fan. Look into the vents. Make sure nothing has got stuck in this fan.
Turn the printer off and on again to see if that clears the 927 error first.
If you are a technician working on a printer with this error that has more than one fan installed, you need to establish which fan is causing the problem. You can perform the following checks:
Check the main exhaust fan first as it is usually the cause. If the main fan appears to be fine, check the cable connecting the auxiliary fan to the printer's engine/system board.
Power on the printer. During the warm-up sequence, both of these exhaust fans are supposed to turn. If one fan turns and the other does not, the fan that is not turning is the most likely cause of the problem.
Measure the voltages coming off the engine/system board to those fans. If one particular fan is not getting voltage, the problem lies with the printer's main system/engine board or that particular fan or cable.
The Lexmark T622/622n model printers also have a fan on the printhead unit. This fan is not visible from the outside of the printer, so you will not be able to check it visually. Power the printer off and on. If that does not clear the error and this fan is the cause of the problem, the printer will require service.
If you are a servicer working on this printer model, follow the steps listed above for the auxiliary fan, but adding this third fan to your list of checks for the cause of the 927 error.
Posted on Mar 09, 2009
I have a lexmark optra sc 1275 I just downloaded the drivers and tried to print but it takes 3 minutes a page. What is wrong?
Probably nothing. This is a very slow 13 year old printer, claiming 7.5 pages per minute for black and .5 ppm for color. Make sure your settings are for black only to get the maximum speed. Even then, manufacturer claims are often high for print speeds, so 3 minutes a page, especially for color, is probably about right.
Mar 05, 2011 | Lexmark Optra SC 1275 Laser Printer
How i can solve the 913 service motor error lexmark sc1275 my printer?
913 Transfer Roller Error
The printer fails to completely transfer the image to the paper or does not transfer it at all.
The image transfer roll does not lift when paper is passing over it.
Suspect either the transfer roller solenoid or transfer roller motor malfunction.
The printer would have to be professionaly serviced by authorized service centre.
http://www1.lexmark.com/content/en_us/technical_support/find_service_provider.shtml
Copy and paste link above for Lexmark Service Centers.
Pre
Jan 14, 2011 | Lexmark Optra SC 1275 Laser Printer
We are receiving the error message "84 oc life exhausted". What can we do to solve?
84 PC Life Exhausted indicates that the photoconductor unit has reached its functional life. The photoconductor kit will need to be replaced. The printer will not function so long as the Exhausted message remains on the display. The only way to clear the message is to install a new photoconductor. After replacing the photoconductor unit, you need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark Optra SC 1275 Laser Printer
Toner Streaks Printouts - Lexmark Optra SC 1275
Check the fuser for scratches. BE CAREFUL - - - VERY HOT ! ! !
If you need guidance for this, let me know.
Aug 12, 2009 | Office Equipment & Supplies
My Lexmark Optra SC 1275 message windo says PC is Exausted
You will need to get replacement Photo Conductor units.
Jul 24, 2009 | Office Equipment & Supplies
Lexmark Optra 1275sc - 900 Service - Software Error
I have the same problem, but the error only occurs when I try to print a .pdf file (Adobe Reader) using the "Lexmark Optra SC 1275 PS" driver. For some reason the PS driver didn't like .pdf files! My solution was to always print .pdf files using the alternative " Lexmark Optra SC 1275 (MS)" driver, which Lexmark also offers on its website.
Apr 01, 2009 | Lexmark Optra SC 1275 Laser Printer
Hello Do you know how to print a test page? cduffy@marsllc.net
From the operator panel, press Menu> or <Menu to
enter the menus.
Note: Before printing the
menu settings page, make sure
the selected paper source holds
A4, letter, or legal size paper
and the Paper Type setting for
the source is Plain Paper.
2 Continue to press and release Menu> or <Menu until
you see TESTS MENU.
3 Press the Select button.
TESTS MENU is then displayed on the first line, and
Print Menus is on the second line.
4 Press Select again to print the page.
Sep 18, 2008 | Lexmark Optra SC 1275 Laser Printer
Error code Lexmark Optra 1275 Printer - 84 PC Missing
Usually there is more to this message particulary if this is a color printer. Basically the printer is telling you that tyhere is a problem in the Photoconducter area of the print cartridge. Normally I would expect to see a 84 PC end of life. Can you tell me if you left some information out, please?
Sep 03, 2008 | Lexmark Optra SC 1275 Laser Printer
My problem with the Lexmark optra sc 1275
Lexmarks use a silicone oil cleaning pad on top of the fuser, try to locate a door on top towards the rear, take it out you might see a long black piece, when you take it out it has a felt on the bottom it is used to clean excess toner off the fuser it should be replaced everytime you change your toner ( usually comes w/the toner).
Oct 11, 2007 | Lexmark Optra SC 1275 Laser Printer
Lexmark printer error at power up
pc stands for photoconductor or print cartridge or in layman's term toner
the toner has reached its expected life or toner has ran out
Oct 03, 2007 | Lexmark Optra SC 1275 Laser Printer
Lexmark Optra SC 1275 Laser Printer Logo
289 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
