Question about Kenmore Washing Machines
I need to replace the switch that starts the washer when it's closed.The switch has fallen apart.Where I can get a switch and what is the approximate cost. The switch is 0.5 HP ,125v and 60 Hz.The washer is 10A 120v 60Hz. Thanks.
    President:
  • 3,113 Answers
I bypassed mine , got a connector and hooked the wires together. Runs with lid up or down, just remember to keep children away from washer and don not reach into tub while running.
Posted on May 23, 2011
Motor not firing up
If your P/W has fallen over a few times (like mine did), sometimes the connectors that plug into the backside of the on/off switch can pop off. You'll probably need to take the case apart to get to the switch to check the connections.
Aug 27, 2014 | Garden
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Washer does not spin or drain. I need a manual for it. It is a 70 Series Model @ 110.82874120
Sears does not make service manuals available for download for free to get a manual you would need to to sears and purchase one.HOWEVER i suspect based on your descpition of the trouble with the washer,i believe the lid switch is going to be the problem. to test if it is that
open the lid
close it slowly and listen for a click when its mostly close
if ya dont hear a click repeat and listen closely
if still no click it's very likely going to be the switch,or the actuator that makes the switch open/close will be broken 279347 359807
to replace the lid switch this video will show ya how to take apart the washer http://www.youtube.com/watch?v=Puq8jWMY9Iw
when looking up part#'s i reliezed this washer was pretty old and if it is the switch or a broken actuator..the wires to the switch could TEMPORARLY be linked together and secured with electric tape,so the washer will work while ordering the part
The part numbers are
SWITCH 279347
ACTUATOR 359807
They can be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
I hope i have been able to help you fix your washer,
GENE
Aug 27, 2011 | Kenmore Washing Machines
The power button broke first, now the button inside on the panel has fallen off and broken apart-I can't use it at all-can't turn on the power..Suggestions???
Hi - sorry there is only one way to sort this one out - gonna have to replace the display module and possibly the decal and faceplate.
If you could copmment back with the product number of the washer I could look up part numbers for you.
Jun 16, 2011 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer model 110 26712690 fills up with water and does nothing. wife said she smelt something burning. I thought maybe a belt but when I took it apart I didnt see any belts.
no belts in a kenmore,if it filled with water and stopped most likely you have a bad lid switch.close the lid,open it up a few inches and close it down a few times,if you don't hear a clicking sound every time you open and close it the lid switch is bad.,if you already have it apart,you can jump it out,the white harness you disconnected next to the right clip is the lid switch harness,stick a wire in the two outside holes,put it on spin and pull the timer out,it will run.the model number you sent isn't correct,i was gonna give you the part number and price of the switch,just give it to your parts store and they will sell you the correct part.
May 15, 2011 | Kenmore 22422 Top Load Washer
When the car turns on the washers come on automaticly and sometimes cant turn them off
i think you need a new stalk switch sounds like the contacts inside the switch have stuck together or fallen apart
Feb 10, 2011 | Volkswagen Polo Cars & Trucks
My tank top starts shootin flames above heater gard
Check that the rivets that hold the outer ring to the inner ring haven't fallen apart. Everything should be tight, if not too much air gets into the mix. I replaced the cheap rivets with screws and lock washers. Did the trick for me. Outer ring may have sharp edges, handle carefully if removing the guards for better access.
Feb 05, 2011 | Mr. Heater Model MH12TS - Single Tank-top...
The hinge of the washing machine has broken - Creda W100FW
The door hinge block has fallen inside the front of the washer.To retieve it, tilt the washer back, and you should find it at the left hand side.
Remove all screws securing 2 parts of door together, prise apart with a screwdriver or similar, and the door will come apart.
You can now access the hinge and all other partsd inside the door.
Trust this helps.
Thankyou.
Nov 28, 2009 | Creda W100FW Front Load Washer
No clips found! To remove top or front
Check out this diagram. Sure hope this helped and best wishes.
Jul 27, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
