Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
CMM1200 mower won't turn on? - Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
  • sdevito May 23, 2011
    Sorry, didn't realize the question went through. Basically I was cutting some long grass and had to pause and pull back every so often as the motor won't quite make it if the grass is too heavy/long. Suddenly the lawnmower just stopped. Put it back on charge and today gave it a try, and it just won't start. Battery appears to be fine (green light on the charger), and the plastic level is fine (took it apart and it looks like B&D now use a metal rod instead of the plastic rod that was causing issues before).
    Tried cleaning some of the contacts, etc. But no luck.
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
How do I repair height adjustment on a CMM1200?
The front wheels link to the height adjustment controlled at the right rear wheel. The spring loaded link arm attaches to a pin on the height adjustment control. The link arm has come off the pin.
Tools: Long shaft bladed screwdriver and a pry bar.
Adjust the rear height adjustment so the second to last notch is engaged.
Position yourself with one knee on the front deck. This will allow you to control the height of the front and the back-n-forth movement of the link arm.
Position the pry bar with the short "L" section upwards, under the lawnmower. This will allow you to control the side-to-side position of the link arm.
Insert the screwdriver from the rear of the lawnmower. The rear wheel axle can be used for leverage This will allow you to control the up-and-down position of the control arm.
A little perseverance and you will be able to position the link arm back on the pin. It may be useful to remove the plastic cover of the lawnmower to allow a better view of the mechanism and link arm
Aug 05, 2012 | Black & Decker Cmm1200 24v 19" Cordless...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Instuctions to replace lawn mower deck
Hello
The only thing I can get you is a parts breakdown . If that helps here's the link
http://www.dewaltservicenet.com/SearchResults.aspx?q=cmm1200 and you just have to see the service tag to check the type you have .
Hope this help
Sep 02, 2009 | Garden
CMM1200
see www.dewaltservicenet.com. look for find it now icon
enter the model # & search
Jul 22, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker cordless lawn mower CMM1200
cmm1200 switch in the handle problem. switch contact maybe burnt out. parts are available. see dewaltservicenet.com or toolpartsdirect.com for diagarm etc.
May 31, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker cmm1200
call B&D 1-800 and ask for a manual
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
277 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
