Question about Car Audio & Video
What does po513 engine code mean on a 2004 chrysler sebring?
    Filmmaker:
    Uploaded 5 video answers.
  • 68 Answers
It means that you have an invalid immobilizer key, or invalid skim key.
Do you have an aftermarket alarm that is remote start compatible? if so, the skim is reading that the car is starting without a key, but the alarm module is allowing it to start, bypassing the skim module.
It says in the owners manual that the skim key module is not compatible with remote start alarm systems. your alarm is bypassing the skim module. the problem with this is that someone can start your car without the key if they can get through the aftermarket alarm.
Posted on May 23, 2011
2004 sebring 2.7 has engine code p0300. Meaning? Possible fixes
P0300 - random misfire ! A vacuum leak , low fuel pressure , ignition system problem are a few thing's that mite cause this problem . Videos on you tube on finding this type problem ! Autolite Challenge Series P0300 Engine Misfire Diagnosis
Sep 22, 2016 | 2004 Chrysler Sebring
What does error code P0040 mean on a 2004 Chrysler Sebring touring
O2 sensors connections for the front sensors are swapped, open (cut) or shorted out. The PCM may be bad if the sensors and wiring are ok.
If you recently worked on the sensors check your wiring. If not, You probably have a bad O2 sensor or the wiring is at fault.
Sep 15, 2015 | 2004 Chrysler Sebring
What does a obd code 2004 means on a 2009 chrysler sebring
see this::
http://www.sebringclub.net/board/viewtopic.php?f=26&t=22397&view=print
Seems to be saying there is a recall on the Throttle body. "Silent recall" they don't want to tell you about it.
Feb 28, 2015 | 2009 Chrysler Sebring Touring
How do I reset a computer on a 2004 chrysler sebring
If you mean clear codes, you can use a scan tool. If you need to reflash the computer to factory specs it would need to be done at a dealer or with an expensive dealer scan tool by some one experienced with the proper data.
Dec 04, 2014 | 2004 Chrysler Sebring
Codes po340 2004 Sebring
DTC code is P0340 no cam signal at PCM. Chrysler always used to say replace the cam and crank sensors together..wouldn't pay our warranty time at dealer unless we replaced both.
Aug 21, 2014 | 2004 Chrysler Sebring
Chrysler diagnosis code 253
My answer is i have chrysler sebring 2002 engine size is 2.7 i have engine light code is 253
Mar 14, 2013 | 2004 Chrysler Sebring
2004 Chrysler Sebring won't start with P0700 error code
Code P0700 just means the trans computer has a code. You need to have the trans computer read to get the trans code p0034 the rubber turbo hose to the inlet manifold which had a small split in it causing it to loose pressure these codes will not make your car not start check battery to see if its dead again does the engine turn over at all when you put battery back in car is terminals tight
Dec 05, 2011 | 2004 Chrysler Sebring
2004 Chrysler ,Sebring Conv Engine Light On code P0610
PCM data configuration error you can pick up an OBD reader from most pats stors for about 50 dollars and reset it but if it continues to come back on you may have to replace the computer (PCM)
Aug 11, 2010 | 2004 Chrysler Sebring
2004 chrysler sebring. no engine codes and car still won't start
try the crankshaft position ensor a common problem it is actually located on the transmission on the backsidea ten millimeter bolt holds it in
May 03, 2010 | 2004 Chrysler Sebring
2004 sebring 2.7 engine, will strt when cold but not when warm
more than likely a bad crank sensor but not knowing if there are codes might also be a cam sensor,it is deffently a electrical componet problem hot soak of the motor will break down bad electrical sensors,
Jan 23, 2009 | 2004 Chrysler Sebring
Car Audio & Video Logo
635 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
