How do you remove the stylus guard? - Audio Players & Recorders
    Brigadier General:
  • 8,546 Answers
Usually they just pivot up out of the way. What make/model?
Posted on May 23, 2011
How to pull out Bosch CS20 circular saw's armature?
There are several steps:
Remove the base height adjustment lever assembly(#56,57,71,72,73,74)
Remove the lower blade guard (#37)
Remove the brushes (#810)
Remove the upper guard housing (#827)
The armature will usually slide out with the upper guard - once out wiggle the armature out of the guard housing.
Reverse order to reinstall
http://www.ereplacementparts.com/bosch-cs20-0601674057-circular-saw-parts-c-128_1138_9632.html
Dec 20, 2016 | Bosch Saws
Elu 172. How do I remove flip top and the safety guard to clean?
Hi mate this is in the wrong category but i have an elu flip saw and to remove the guard you take your blade off and guide bush and remove the circlip and the guard pops off but u need to make notes on where the guard return spring fits through a hole on guard so as to replace, and remove the bolt with the screw driver slot in and washer / spacer to detatch the folding arm inside the guard, i will check mine and jog my memory then get back to u,does yours have a duel size bush for different blade diameters / centres. Paul
Sep 19, 2015 | Garden
How to I fix a Ryobi Miter Saw Blade Guard which is not retracting?
Sound like a piece of wood may have driven the arm up which operates the guard, if you remove the screws holding the guard support plate to the saw you should be able to remove the guard assembly, the arm can then be re-bent down on the end so that it meets the angled plate on the back of the guard and pushes the guard through the entire stroke, the other reason could be a damaged guard, when the centre screw is removed the plates can be removed from the guard, note how the spring and plates are assembled prior to dismantling, check the inside centre of the perspex guard and ensure the 4 protrusions which engage with the drive plate haven't broken off, if sow the guard will need to be replaced, this may now be an obsolete part , if so purchase a Makita guard as they are the same
Jul 18, 2015 | Ryobi 10 In Miter Saw With Laser
B & D #3051 worm drive saw: How do I access the return spring for blade guard?
Link,
Usually you will have to remove the blade guard to get access to that. There is usually a rubber stop with a screw going through it that you will have to remove, and a spiral spring clip on the inside of the hub of the blade guard that will also have to be removed and then you should be able to lift the blade guard off the saw. The spring will hook around the blade guard and the other end will hook to the saw housing. Hope this helps!
Apr 22, 2015 | Saws
Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
Jul 26, 2012 | Husqvarna Garden
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Well im not too sure if my needle is broken but when i play a record i cannot hear sound and it sounds like my record is being scratched. Do i need to keep the white cap on the needle or not? or is it just...
    It's called a stylus. What red or white caps are we talking about? Some phono cartridges come with stylus guards that flip up out of the way for play or down to protect the stylus from damage while in storage or during tonearm balancing. The stylus needs to touch the record groove directly.
    Jul 14, 2010 | Numark ttUSB Turntable
    I have an epson stylus nx100 printer but I can't seem to get the paper in the right spot so it will print. Where does it go?
    ***hi there,ill be willing to help you on that. ****
    Load Paper for Documents
    1. Open the paper support, then open the output tray and pull out the extension.
    2. Flip the clear plastic feeder guard forward, then squeeze the edge guide and slide it left.
    3. Insert paper, printable side up, against the right side and beneath the tab.
    4. Slide the edge guide to the edge of the paper, but not so tight that the paper bows.
    5. Flip the clear plastic feeder guard back.
    ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
    Sep 17, 2009 | Epson Stylus NX100 InkJet Printer
    How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
    you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
    Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    Each time I print on plain paper the paper feeds into the machine and when it hits pinch rollers after the print head, the top right hand corner is turned over. Two pages later and the third page is so...
    Follow these steps to reload paper:
    1. Flip the feeder guard forward.
    2. Remove the paper and make sure it's not curled or wrinkled.
    3. Fan the stack of paper to make sure the sheets are separated.
    4. Reload the paper against the right edge of the sheet feeder andslide the left edge guide against the other side, but not too tightly.
    5. Don't load paper above the arrow mark on the left edge guide.
    6. Make sure the printable side of the paper is facing up.
    7. Flip the feeder guard back.
    8. Once you have completed the steps above, press the cp_button_6.gif Start button.
    Mar 07, 2009 | Office Equipment & Supplies
    22 people viewed this question
     Grubhead
    Grubhead
