Question about Eljer TITAN 15" Two-Piece Toilet - 09
My house was built in 1985 and has Eljer Toilets. I'm trying to find the factory replacement parts for these toilets. How do I find a model # or type of toilet so I can order the factory parts if they are available.
    Top Expert:
  • 75,157 Answers
Hello
Get into this link where you can download your toilet's manual, spare parts diagram and its numbers etc
www.eljer.com/productDetail.aspx?id=2505
Click on download link to get these.
If you feel any diffculty in downloading the site, send your email address to me by FixYa. I'll send you the documents to you by return mail. OK.
Posted on May 23, 2011
Where do I find a part number on an Eljer toilet tank?
You can purchass a whole new fixture for the same cost as just the tank I believe...
any eljer tank will fit your toilet bowl... they are pretty universal.
Does the current tank have a crack or something?you can replace the seals easilly enough if the tank is just leaking at the seal ... and the flush mechanism is also easy to replace , should that be the reson to swap out tanks too.
Mar 24, 2013 | Eljer 141-0220-00 Toilet Tank White
Need installation instructions for eljer pf2 energizer power flush
Insufficient information to identify your toilet. Go to this site:
http://www.eljer.com/searchResults.aspx?t=3
If you are able to pick up your toilet model or a simialr model; click on the image; click on the Download Tab.
You will find a Spec Sheet, Installation Instructions and Repair Parts Diagram.
Mar 03, 2011 | Eljer Home
I am looking for a replacement toilet tank lid for a Eljer Preserver II toilet. Manufactured in 2003.
I checked the Eljer website; several different toilets came up searching with the number you provided but
no information on a Preserver model.
I think your best bet would be to contact your nearest dealer for the Eljer products. You can use the location finder on the Eljer website:
http://www.eljer.com/dealers.aspx
It is possible a dealer may have old stock oand should know if there is a substiute available.
Mar 02, 2011 | Eljer Toilet Tank Lid Preserver II ...
My eljer toilet leaks between base and back. it has a built in overflow. there is no overflow tube. i change gasget but still leaks.
Look for cracked ceramic at gaskit joint might need to replace tank..I did after weeks of trail and error.
Nov 28, 2010 | Eljer & Savoy& Toilet Tank With Lid
I have 40 year old eljer toilets seat cracked,
This website appears to have what you need
http://www.plumbingsupply.com/eljertoiletparts-patriot.html
Hope this helps?
Jan 20, 2010 | Eljer & Patriot& Elongated Toilet Bowl
I cannot get the flapper to seal properly. I have tried at least three different flappers. The toilet is in good condition and ablut 20 years old.
i had same problem. higher end toilets use specialised parts, and the regular parts at the hardware stores usally fit only regular cheap toilets. i would recommend trying to get the original part from manufacturer, or plumbing only supply store
Sep 05, 2009 | Eljer & Elongated Toilet Bowl
I havve two Eljer non-wateraver toilet (Patriot?)
I've never had a problem with Eljer toilets. Try adjusting the fill valve so that it allows more water to enter the tank (if you're over the flush valve, install a coupler made from PVC around the neck of the flush valve- inside diameter of the coupler needs to be the same as the outside diameter of the flush valve filler neck).
Jul 02, 2009 | Eljer Home
Flush valve
it is all one piece,replace it with the same model. a plumbing supply house is the only place you will find what you need.
Jul 01, 2009 | Eljer Toilet Onepiece Canterbury ...
Eljer TITAN 15" Two-Piece Toilet  - 09 Logo
218 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
