Question about Canon PIXMA IP5200 InkJet Photo Printer
Hello; My Pixma 5200 was like dead. So I tested the power-supply unit. No current anymore at secondary ( 24v and 32v) The fuses are ok.. I'm looking for the circuit diagram of this printer or the diagram of the power supply unit. Anyone? Thanks a lot Vincent
  • vincent_rena May 24, 2011
    Thank you asbbhyuuu, I'm sorry because I din't see in your list a link to solve my problem. Do you remember what you've made ?
    Thanks;
SOURCE: How to check the PSU for IP3000 printer
I've just checked mine as it suddenly stopped working - does not even light up the green button.
I'm getting 8 volts Red to Black and 23 volts Red to Yellow so I guess it's fubared?
Posted on Jan 28, 2008
SOURCE: driver for printers canon ip 1800 on win 98
download
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: service error 5200 on a cannon pixma ip3000
Found the solution here: http://www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
It's a PRINTHEAD problem - open your printer and check the cartridge - it may be out of line. John
Posted on Apr 25, 2009
benwabnick
  • 2404 Answers
SOURCE: Not working power supply unit, need replacement
Here is one courtesy of Azsurplus.com
http://azsurplus.com/index.php?main_page=product_info&cPath=2_16&products_id=1207
Cost is $24.99 before and S/H costs. Hope this info helps.
Ben
Posted on May 16, 2009
MNfisherman
  • 11896 Answers
SOURCE: Canon Pixma 5200 printer power will not come on.
First thing to check for is the fuse. You can lift off top cover and look by the power supply. There should be a glass bus fuse there. It should have a thin wire running all the way across it if it's good.
If the fuse looks good, the next thing would be to test the power supply voltage with an voltmeter.
Posted on Nov 24, 2009
REPER AC ADAPTER K30263
K30263 Adapter..... is REPER "REPAIR"
CANON K30263 AC ADAPTER 32VDC 0.9A 24V Used POWER SUPPLY PIXMA M
$59.99
Condition : Used
Content : One Adapter only Manufacturer: CANON
Model Number: K30263
Part Number: QK1-2228-000-DB01-01
> Input Voltage: 120-240V~ 0.9A 50/60Hz
Output:
32V === 0.9A
24V === 0.5A
24V === 0.03A
Output Connector Type : 2 rectangle White Flat
1 x 2Pin, 1 x 7Pin [ • • ] [ • • • • • • • ]
Dimension: 17 x 10.5 x 7 cm approx.
Weight: 310 grams approx.
Compatible with: Canon Pixma MP830 Printer K1027 K10270 QC1-9029-DB01-01
http://azsurplus.com/index.php?main_page=product_info&cPath=1_24&products_id=1211&language=en
Feb 26, 2015 | Office Equipment & Supplies
Hi i have a hitachi ax m140 power amplifier there's no standby light dead can you help please
Check the power supply rails on the secondary side of the power
transformer.
• Check the presence of AC outputs on the transformer secondary
windings
• Check the diodes and capacitor circuit
• Check the regulator circuits
Post image so we can undestand better ( only if possible )
and guide you accordingly.
Aug 02, 2012 | M-Audio Audio Players & Recorders
MA203DT monitor dead again
I think it's trying to tell you something!
Time for a funeral. Best get a new monitor.
Oct 03, 2009 | iiyama MA203DT 22" CRT Monitor
Philips CRT Monitor 107 E66 SMPS dead Pls any one
The monitor might be 'dead' because the flyback transformer (specially primary section of it) is not working. You can try replacing it if it doesn't cost you too much.
Jul 22, 2009 | Computers & Internet
Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Oct 01, 2008 | Heating & Cooling
Dead Monitor
the monitor is dead
Jul 26, 2008 | Compaq V700 17" CRT Monitor
Unit is dead....
The power supply is the first place to start.
Is there a transformer? Check to see that there is AC on the primary & secondary of the transformer.
If no AC on the secondary, then the transformer is bad. If AC ok on the secondary, then look for a bad rectifier diode/module and/or regulator module. There might also be fuses on the DC side of the power supply.
If the unit is completely dead, it's most likely a power supply issue.
Please let me know if I can be of further assistance to you.
- Jim
Feb 08, 2008 | Panasonic WV-CM1020 Television
Whirlpool MH6151XHT-1 - No Power - Stumped
First change all the fuse and check whether it works or not, if it does not work than as per your finding the secondary transformer could be the issue, the secondary transformer tap down the voltage fro 230-240/110 to required control board voltage. the best thing if the unit is opened then the right problem can be found but as per your description either fuses are faulty or the secondary transformer.
Dec 12, 2007 | Whirlpool MH1150XMQ Microwave Oven
Canon PIXMA IP5200 InkJet Photo Printer Logo
194 people viewed this question
old marine
old marine
