Can not find the toner bottle on my GEI 2900 large scale plotter. Getting a Error message that the bottle is full.
SOURCE: waste: near full
take the waste bottle out & empty it. I have never had to buy a new one.
Posted on Sep 27, 2007
jaylex
  • 417 Answers
SOURCE: We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Posted on Jan 28, 2008
  • 15 Answers
SOURCE: waste toner bottle - Ricoh MP W2400
Just an FYI, this can be very messy. If you figure out how to get the thing out (should be near your consumable supplies like toner and image units) place the whole unit into a plastic bag, tie the bag, then shake it out gently. You may have to learn how it opens in order to "open the door". Best to use a vaccum with a heppa type filter as normal vaccum filter is too course for the fine toner partcles. Be ready for toner volcano.
Posted on Jun 09, 2009
  • 97 Answers
SOURCE: My Oki C9600 Printer showed an error message,
940: Error
Waste Toner Transfer Error
The transfer mechanism of the
toner duct for ID is not operating
properly.
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
printer).
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
board.
Replace the duct assembly
toner.
Posted on Mar 29, 2010
SOURCE: How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Posted on Dec 18, 2010
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
I get error message "waste
Open the right side door. there at the bottom is a long plastic bottle full of waste toner. If you have no spare bottle then carefully (dont create dust) empty toner into a bin liner. Now tap the bottle on the table to allow any toner on the sides to fall back to the bottom. now refit and all should be well.
May 10, 2011 | Lexmark C544dn Laser Printer
I have a Ricoh Aficio MP W2400 plotter. new message is waste toner bottle is full. i know that a service tech is supposed to replace it but due to the weather i cant get one over here. can i empty it for a...
This is for a W2400/3600 which should I assume is the same spec for other Ricoh wide format machines. When you are facing the printer from the front, it's on the right side panel. The waste toner bottle should be about 28" from the ground. Remove all right side panels. There is a sensor (held by phillips screw) that you will need to temporarily remove and reinstall back on to the waste toner bottle once it's emptied. Replace all right side panels. You are good to go. No need to call service tech to waste time. Should be a 30 minute change.
Feb 04, 2011 | Office Equipment & Supplies
How to remove error code e000019-0000 in canon photocopy ir3200 machine
This is a code for the waste toner bottle being too full. The copier usally displays that the waste toner is getting full and needs to be dumped. But if the customer ignores this message for too long it goes into this code. Empty the waste toner bottle behind the front door. Be sure to clean the neck of the bottle also. Reinstall the bottle and power down the copier and turn it back on. Things should be OK then.
Jan 25, 2011 | Canon imageRUNNER C3200 Copier
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
Error 357 waste toner full
If you dumped out the full waste toner bottle The gear that drives the gear on the waste toner bottle has broken off.
Dec 18, 2008 | OKI C9600hdn Laser Printer
Ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
125 people viewed this question
jasbo
jasbo
