Question about U.S. Robotics MAXg USR5461 Router
Release ip address. I want to be seen on the internet with a different IP address. When I plug the cable modem directly into my computer I can release and renew and get a new IP with the network card, this works every time. But when the modem is plugged into my router first, I can't change it and it's been the same address for a couple years. In the router's admin page there is no way to release the ip address before renewing it and just renewing the lease does not change it. What can I do, is it possible with this router to change the IP address? Note that I'm speaking of the address that is assigned by the cable ISP. This is a US Robotics MAXg wireless router.
  • 51 Answers
The easiest way to release and renew your IP with a router that doesn't have that feature is to unplug the modem (not the router) for a few minutes - overnight while your sleeping to be sure.
Posted on May 23, 2011
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Can someone show me how to change my Dell lattitude e5520 ip address?
Your IP address is assigned by your network system.
If you have a conflict with your IP, you can try a ipconfig /release or ipconfig /renew.
At the command prompt type
ipconfig /? for all available switches.
If you are using a cable modem, you would want to reset to factory first.
May 03, 2014 | Office Equipment & Supplies
Hpow u change ip adres
Method 1:
To release and renew your IP address:
Step 1
Go to "Start > Run" and type "cmd" (without quotation marks), then select "OK"
Step 2
Type "ipconfig /release" (without quotation marks) and press "Enter"
Step 3
Once the prompt returns, type "ipconfig /renew" (without quotation marks), then hit "Enter,"
Step 4
Last, type "exit" (without quotation marks) then press "Enter" to close the window.
you have a new ip address.
Method 2
It's simple to change the Ip-address..You can reset the modem or switch for a minute and the switch on it..Check the ip-address at www.ip-details.com if your ip address changed .It's Dynamic ip address ....You can change it many times by resetting the modem...Before changing check your previous ip ,so that you can know the difference.This is will not work if your ip address is a static ip address...Static ip will not change even if you reset the modem.
Method 3:
You can use proxy server or hide ip address software to change the ip address...But it's not legal to hide ip address always.It helps to hide your ip address from hackers..So whenever you need you can hide ip..Don't hide ip address always.You can also display your ip from Canada using proxy,even if you are in USA.
Aug 07, 2013 | Computers & Internet
I reset my modem and now i cant get my wifi back on
If your modem pulled a new or different ip address and you did not reset your router it could be trying to use the old IP address and there would be a conflict. IP addresses usually have a lease of 24 hours, S if your IP was refreshed at noon and you reset your mdem and for sopme reason it obtained a new ip address the router would not be able to connect until noon the following day when it tried to refresh. Rebooting the router should cause it to sync back up with the modem and pull the correct IP address. You may need to log into your router and manually release and renew the IP address even after rebooting your router, I have seen a few routers that would still not pull the new address unless this was done.
My preferred method is to unplug power from the router, then reboot the modem. Only after the modem is synced back up do I plug power back into the router, so far this has seemed to work the best.
Jan 30, 2013 | Smcd3gn-res Wireless Router Cable Modem...
Hi, Our modem seems to work fine when plugged directly into a computer (we get internet okay), but if we plug it into anything else it won't get internet. We've tried two different routers and a Wii and...
Without further information, my best guess is that your modem has the same IP address as the common IP address for routers and probably the Wii. Most wireless routers have the address 192.168.1.1
Try connecting a computer using a hard line (a network cable) to your router and type in this address, it will most likely come up. If it does change it's static address to 192.168.1.12 (actually any number behind the last period above 1 and under 255.). Also set its gateway to 192.168.1.1 to access your modem. (Also in the router settings which are found by typing the address mentioned above, 192.168.1.1) Be sure to note this new address if you want to access your router without resetting it and using a hard line again. The Wii should automatically pick up signal from the wireless router. If for some reason you want to switch between the Wii and a Router by way of hardline, you must contact the maker of your cable modem (or cable company) and find out what the IP address is in order to access it's settings (the same way; by typing it's IP address into a browsers address bar.) By setting the modem to have a different IP there would be no conflict with the other products which (rightly) have the IP address of 192.168.1.1 as a default.
Hope this helps!
Dec 08, 2010 | Zoom 5241 Modem
My dsl internet light stays red when plugged into the router, but okay when plugged into my computer
print2.gif print email2.gif email
Title: Setting up Cable Internet for the RV082 Article ID: 16585
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is assigned a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys router to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a router to copy the MAC address of the PC that's registered with the ISP.
NOTE: Before proceeding, use the computer that can go online when connected to the modem and follow the steps below.
Step 1:
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your ISP. If it can go online, the PC connected to the modem is the one that's registered with the ISP.
kb16585_001_en.png NOTE: The image may vary depending on the computer and modem you're using.
Step 2:
Once an active Internet connection is established through the modem, connect the modem and the computer to the router by following the instructions below.
Step 3:
After ensuring that you have an active Internet connection, connect the modem to the router's Internet port and the computer to any of the four Ethernet ports.
Step 4:
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router. For instructions, click here.
Step 5:
Access the router's web-based setup page. For instructions, click here.
Step 6:
Go to the Setup - Network, click the drop-down arrow under the WAN Connection Type field and select Obtain an IP automatically for WAN1.
kb16585_002_en.png NOTE : If you are going to have another Cable Internet as well in WAN2, select obtain an IP automatically as well.
Step 7:
Click Save Settings.
Step 8:
Check in the System Summary if the router is getting a WAN1 IP or WAN2 IP.
NOTE:
If there are no IP addresses seen in this field, go back to Setup then click the More option to reveal the MAC Clone settings.
Step 9:
Select MAC Address from this PC.
Step 10:
Click Save Settings Button.
Step 11:
Click System Summary. Check the value of the WAN1 or WAN2. If these have numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're not online, perform a power cycle to synchronize the router with the modem.
kb16585_007_en.png NOTE: If the WAN1 IP or WAN2 IP is all zeroes (0.0.0.0) click first Release then click Renew buttons. If the WAN1 IP or WAN2 IP is still all zeroes (0.0.0.0) perform a power cycle.
If the IP Address starts with 192.168.1.xxx or if it has the same first three numbers (octets) as the router's IP address, change the router's LAN IP address to a different LAN segment.
Step 12:
Once the router is configured, perform a power cycle. Shutdown the computer and Unplug the router's power cable. Unplug the Broadband modem's power cable and wait for 30 seconds then plug in the Broadband modem's power cable and wait for its lights to appear stable. Plug in the router's power cable once the modem's lights appear stable.
Step 13:
Power on the computer on and test the Internet connection.
NOTE: If you're not online after performing this procedure, you may need to upgrade the firmware of the router. For instructions, click here .
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 25, 2010 | Linksys RV042 VPN Router
I have cable internet through Time Warner and their modem connects directly to my Dell Dimension 8200 PC. I cannot connect to the internet and I am told it is because my computer will not read the ip...
you need to flush your dns
unplug modem (min of 10 sec)
turn off pc
restart in this order
modem (wait until most of the lights are solid) then pc
if your still having trouble
--------------------------XP Only -----------------------------------------------------------------
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
---------------------------------Vista or higher----------------------------------------------
1) Go to Start and click Run.
2) Run window will appear. Type cmd and click OK.
3) Command prompt
window will appear. Type ipconfig. You then will see the IP address and other network information of your network card
4) Type ipconfig /release to release the IP address.
5) Finally type ipconfig /renew to get new IP address.
then if this dont wont restart the computer.
if its still not working you will need a local tech to see if the ip address is hardcoded into the NIC
Jan 06, 2010 | Dell Dimension 8200 PC Desktop
Error in Connecting
without the modem plugged into the troubled computer, go to start -> run.
Type cmd and hit enter. A black window screen will come up. Type ipconfig and hit enter. Without the modem plugged in, your ip address should read 0.0.0.0. If not, you have a manual ip address and need to change it to auto.
To change ip address to auto, (in windows xp) go to start -> control panel, or start -> settings -> control panel.
Double click network connections. Look for your local area connection, right click and click on properties.
A window should popup. Scroll down the list to Internet Protocol and click properties again. Make sure IP address and DNS are both set to automatic.
Mar 18, 2009 | Arris SURFboard SB5120 Modem
Change ip
Your IP address is assigned (leased) to you from your internet service provider. With that being said, you could possibly call them and ask to release your old IP address and have them assign a new one. If you happen to have a static IP address assigned from your ISP you can call them as well and ask to have your IP address changed too. It would be up to them to change it though.
Sep 14, 2008 | 2wire (1000-400108-001) Router
U.S. Robotics MAXg USR5461 Router Logo
346 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
