My computer is on but on the screen it says self test feature check with a list of colors. What do I do from here?
    Scholar:
  • 78 Answers
Welcome to FixYa!
First of all, kindly check the cable connection of the monitor going to the computer.. check if it is connected properly to the computer
I've also sent a message to ask for a clarification for this.
Posted on May 23, 2011
  • 243 Answers
Try to check the vga cable (from your monitor to the cpu)make it tight, if it can't fix your problem turn off your computer, open the case, remove your memory (RAM) and try to clean it with pencil eraser, put your memory again to your mainboard and turn on your pc, if this can't fix your problem maybe the display adapter (VGA) is broken, if you use and external vga try same way with your memory, if you use an internal vga you should find another vga to test on your cpu
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
Self test feature check stuck on screen
from my past history dell has/is problems with the E153pc and the E172pb is it under warranty and have you gotten hold of dell about this I have had cases where they have replaced monitors.
sorry it was no great help but dell knows of this problem. dont let them bull**** you.
Jul 21, 2010 | Dell E153FPc 15" TFT LCD Flat Panel...
Screen is showing "Self test feature check" in a box with primary colors floating around the screen.
it mean that
* either the data cable which goes from computer to monitor is loose or bad
* the computer is off or not turning on .
Apr 09, 2010 | Computers & Internet
My monitor is blank it just keeps saying self check its a dell flat screen
If it shows "Self test feature check" the cable (VGA / DVi ) is unlplugged on the computer/ tower. Check the cables it may be loose. If not, try replacing the VGA/DVi cables. The LCD is good since it was able to display the self test feature check.
Hope this helps.
Mar 24, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My computer is showing a floting box which say self test feature check, wit red,green blue and white box.What do this mean
its showing u monitor self test feature screen issue either with the monitor cable or monitor or the graphic card
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
My screen is showing Self test feature check and will not stop! Help!
The first thing to check is--is your computer actually running?
It sounds like your computer is either off or it is not sending a video signal to the monitor.
If there was a signal going to the monitor, you would be seeing something other than self test.
There is also probably a menu button on the monitor. Find it and push it to reset the monitor.
Now check your computer--preferably with another monitor to see for sure what is going on.
Oct 22, 2009 | Dell Computers & Internet
Flat Panel Monitor: 1907FPt
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
