Question about Brother HL3040CN Laser Printer
Dark black line on lefthand margin of paper going all the way down the paper (1/4 thick line)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 306 Answers
That is mean the lifetime of drum is over.
solution. replace a new.
Posted on May 23, 2011
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Mar 10, 2015 | Xerox Office Equipment & Supplies
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
The problem is with our Church (HP 6500) office printer . When we are making copies of a document, the printer prints a solid line down the length of the paper on the lefthand side margin ( about 1...
Yourprinter ink has spiltonto the main ICU and needs to cleaned thoroughly. This is a job for a technician. The ink is all over the roller. It will only get worse. It now needs a techy to cleanproperly.
Jan 18, 2011 | HP Officejet 6500 Wireless All-in-One...
Copying very dark lines down page.
hi just clean complet scanner mirrors and charge and transfer crona wires if solved ok if not solve just replace the drumcleaning blade.
thanks
May 14, 2010 | Toshiba 1370 Black and White Copier
Black line down lefthand side of screen about 1" thick
The monitor is old. It could be slightly adjusted. But when you start getting lines, soon the image becomes blurry, and during CRT death the Cathode Ray Tube radiates 100 times the radiation of a healthy monitor.
Sep 06, 2009 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Black Line
Take glass cleaner and clean the small strip of glass to the far right. If there is a speck on that strip of glass it will cause a line when it scans.
May 02, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Black line down right margin
Have you tried a new toner and drum unit? if not please do so. If that doesn't work then it is a scanner lamp failure and will need replacing.
You can fix it but trying to obtain this part for such an old machine will be hard. Don't know the part number sorry.
Thanks J
Jan 30, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother HL3040CN Laser Printer Logo
301 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
