How do I remove the filter to clean< I don't have the manule
    Brigadier General:
  • 4,736 Answers
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 23, 2011
  • Rich Landrum May 23, 2011
    Please disregard the this response. It was meant for another questioner. However, if you can provide the brand and model number of you air conditioner, I may be able to help you. Thanks. Sorry for any inconvenience the previous reply may have caused.
My dishwasher isn't draining after it's cycles.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Whirlpool DU912 Dishwasher
Won't drain after rinse cycle.
Hi
Daniel
Aug 14, 2011 | Maytag Dishwasher
My 665 won't drain. Any idea what the issue is?
Hi
Daniel
Aug 09, 2011 | Dishwashers
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
I have a Matsui MF2W dishwasher that will not drain. Theres always water in the bottom. The exit tube rises to the pipe at a height of 90cm which is < 100cm as ststed in the manual Could it be blocked?...
Hi
Daniel
Jul 21, 2011 | Dishwashers
Water didn't drain
Hi
Daniel
Jun 19, 2011 | GE Nautilus 24" Built-in Dishwasher
Asko dishwasher filter at bottom of unit collects food waste - how do you clean?
Keep in mind that there are two filters:
Coarse filter
The coarse filter collects large food particles
which cannot pass the outflow pump.
Lift out and empty the coarse filter as
necessary. Don't forget to replace it!
Fine filter
The residue which collects on the fine filter is
automatically rinsed off with each wash. The
fine filter should still be cleaned once or
twice a year.
1. Remove the fine filter by first turning the
filter's tubular strainer anti-clockwise and
then lifting it straight up with the coarse filter.
2. Clean with a dish washing brush. Ensure
that the edges are properly sealed
Download the manual and go to cleaning page.
Jun 05, 2011 | Dishwashers
How to add internet settings(APN) for Samsung Behold 2 T939
or anyone wanting to know how to change their APN settings for future reference here it is:
on the keypad type *#87927# and wait until the APN setting pops up. click the APN available.
then change these settings.
name : t-mobile us 310 260 ----> name : simple
APN : epc.tmobile.com ----> APN : simple
proxy : not set ----> proxy : 216.155.165.050
port : not set ----> port : 8080
username <leave blank>
password <leave blank>
server <leave blank>
mmsc <don't change>
mms proxy : not set ----> mms proxy : 216.155.165.050
mms port : not set ----> mms port : 8080
mcc <don't change>
mnc <don't change>
apn type <don't change>
authentification type <don't change>
after that just back out and give it a few minutes. as long as you have the data plan your 3g icon should show up ready to go.
Aug 30, 2010 | Samsung Behold II SGH-t939 Smartphone
Where is the oil filter for a 2005 chevy cavalier located
ECOTec 2.4 Liter engine (and all ECOTec engine blocks in 4 cylinder sizes) have a cartridge type oil filter housing on the front of the block, driver's side of the vehicle.
The cap must be removed with a wrench, and the filter pulled out, then the new one put in. Now is usually a good time to replace the O-ring on the cap.
Dec 13, 2009 | 2005 Chevrolet Cavalier
Doesnt pick up water
Possible Causes Remedies
ReadyTools Dial may be at the wrong setting for the cleaning job <> Set ReadyTools <> Dial to either Tools / PreTreat or Floor Cleaning.
Nozzle Window may not be properly attached. <> Press down firmly on the black oval gasket at the top
Window to make sure the two tabs on the back of the Nozzle Window are snapped into the mating slots in the main housing.
Tank-in-Tank lid is not installed <> Re-install lid;
Tank lint filter is blocked <> remove all lint and debris from Tank lint screen.
Tank-in-Tank is not properly seated. <> Tank-In-Tank must be firmly seated to function; remove
and reseat Tank-in-Tank.
Poor tool position (Hand held attachments only). <> Adjust angle; apply more downward pressure.
Tank-in-Tank has picked up maximum dirty water <> Empty Tank-in-Tank
Front Clear Floor Nozzle Window ids blocked <> Remove window and clean all fibres and debris then replace.
Insufficient suction <> Clean Pre and Post Motor Filters.
Sep 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
