Question about Hotpoint SY21 Style Line Gas Single Oven
Clock Stopped Working on my wall oven Model # WS 820 H-1 Serial# AB 197826
  • 833 Answers
SOURCE: Jenn-Air built in oven Model W188-C, Serial # 210764UC approx 1987
Big oops, Millwood. Shut power to the unit immediately and wait a day or more for it to dry out. If it works then, fine. If not, you've got a learning experience installing a new pad.
Posted on Dec 07, 2007
murdozzz2
  • 75 Answers
SOURCE: my oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Posted on Dec 09, 2007
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
  • 1531 Answers
SOURCE: FRIDGEDAIR WALL OVEN fec50k1 JUST STOPPED WORKING,
you need to replace the main control board or set it up for service to check the internal fuses
Posted on Sep 27, 2009
ovens61
Can this be repaired?
Posted on May 01, 2016
How to bypass broken clock on eurolec 720ef electric wall oven
If you bypass the clock, how will you maintain a steady temperature, include safety features, or program functions?
What you seem to want is an outdoor grill. DO NOT bypass the logic board on your oven, sir. Help Me Find My Model Number RepairClinic com
Jun 14, 2016 | Ovens Ovens
Belling evolution 152 main oven stopped working and clock gone out.
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Oct 14, 2014 | Ovens
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
My oven display has "sABBATH" written on the
May I get the make and model # to help you more. On some ovens if you hold the clock button for secondes it should turn off. I need the make and model # to be-sure.
Apr 24, 2011 | Maytag 24" Built-In Single Electric Wall...
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
My wall oven's heating elements stopped working. Clock, enterior light still work.Model REG74BL*3
Sounds like one leg of the 220v ele. supply has tripped. All thats working, works off of one leg. The elements need both legs to heat. Find your breaker for the oven, reset breaker. It may look ok, but flip the breaker off and then back on. This should fix it.
Please rate solution
Sep 02, 2009 | Frigidaire Ovens
Put in new wall oven , turned on power and set
my kenmore double oven model 41165 has no power....its hardwired 40 amp....it stopped working when it was cooling down after the slf cleaning cycle..we had a storm and had a minute power outage. Finakky got the door open but it wont turn on at all. Tried the breakers but i stll get no power....no even the bulb.......thanks....
Jun 07, 2009 | Ovens
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
Clock
What country are you in. This model does not show up in Kenmore USA
Perhaps you gave me the serial number by mistake, rather than the model number?
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Open Questions:
See all Hotpoint SY21 Style Line Gas Single Oven Questions
Hotpoint SY21 Style Line Gas Single Oven Logo
52 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
