Question about Cameras
I was reading input from your website. The black cylinder fell out when I turned camera upside down. I don't know where to put it back in.
    Sergeant:
    Champion:
  • 214 Answers
Hi Would you tell me more about your camera information? First, the name of camera.. second, lens if DSLR..third, which location of piece you see.---it looks like DSLR... Thanks and best regard! you can skype me at any time after 6pm.
Posted on May 23, 2011
I have a Canon Rebel XT. After taking a picture, the viewer shows the shot upside down and when I down load to my computer they come in all upside or sideways. Just started doing this and I've had
The EOS cameras have some sort of sensor built in to tell the camera which way the shot should be orientated on screen and when they are transferred to the computer.
It sounds like the sensor is jammed or broken and sensing (for some reason) that the camera is upside down when the shot is taken.
If you don't want to pay to have it repaired you can use a program to rotate them or turn of the image rotate option in the menu. I believe this ignores the sensor information.
Jun 24, 2012 | Canon Cameras
It says paper jam i don
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also turn the printer upside down. Any debris should just freely roll out from the feeder.
  4. If the feeder is clear, place the printer back on the table.
  5. Open the printer cover and remove the cartridges. Check the cartridge area for any obstructions in the cartridge carrier's path or the paper path.
  6. If cartridge area is clear, close the printer cover.
  7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in on the back of the printer, and put it back in after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Should the problem continue, please contact Lexmark Technical Support Center for further assistance. Thanks.
Nov 17, 2011 | Lexmark X5495 Printer
My camera fell in the sand I don't know if the sand got stuck in it & I don't know if that is what is causing the problem with the lenses not opening
is it notifieing you that there is a lens eror? or does it just not turn on? This type of problem you won't be able to fix yourself, and don't try to either! You will need to contact Kodak and tell them there is a lens eror (don't give details that you shouldn't be giving), hopefully they will be willing to fix it for you or replace with refurb.
Aug 30, 2011 | Kodak EasyShare M1093 IS Digital Camera
Water fell on my dell inspiron mini when it was on .now when i m trying to put it on it say that ur computer is unable to start
If you don't know how to disassemble it or anyone who can repair it for a fair price, try leaving it in sunlight upside down for two hours.
I don't know which part of the world you are from, so I don't know how much sunlight you get, but make sure it doesn't get too hot.
Aug 13, 2011 | Computers & Internet
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
The rod holding the chuck fell out. I can put it back in part of the way and it will still drill as long as it is not pointed down but I don't know how to get it to stay locked in place.
You don't need that screw that fell out if you can't get it back in the chuck is threaded on and you probably will never have a problem with it again. Good Luck...
Apr 19, 2011 | Black & Decker BD12PSK 12-Volt Smart...
Canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Oct 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
False paper jam
Turn it upside down and shake it. then check the input tray. Also, chck the jam switch. it's a microswitch in the paper path. it could be bent of stuffed with a small piece of paper.
Aug 14, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
