Question about Drills
DeWalt D25303/4K Clutch slips too easily under light torque in rotary mode. Hammer action working ok but chuck is not locking in position when in hammer only (chiseling) mode. New clutch assembly needed or is it simpler than that?
4 Suggested Answers
  • 2712 Answers
SOURCE: usage Problem
Yes, but you have to use an auxiliary 3 jaw chuck adapter and you do it.
Posted on Aug 27, 2008
joboo1
  • 257 Answers
SOURCE: 24v dewalt dw005 was using my drill in chisel
Hi, You should take it back while the warranty is still fully intact as this is a problem and will not resolve itself.
Good Luck to you, this should Fixya!
Posted on Mar 23, 2009
  • 969 Answers
SOURCE: DeWalt 567 rotary hammer won't hammer
If still under warrenty local Dewalt store will repair. Total rebuild $99.00 on most tools.
Posted on Nov 07, 2009
My dewalt dc223 has a normal chuck on it but no sds chuck.. will this stop the hammer or is it broken?
If someone replaced the chuck the hammer part likely failed and it's a normal drill now, the hammer function would destroy a regular chuck.
May 10, 2014 | Dewalt DC223KA Heavy Duty 24 Volt 7/8 Inch...
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
How do I remove the screw holding the keyless chuck. Dewalt cordless 18v hammerdrill, I know it's reverse thread but it still will not come out. Is there a locking mechanism?
sometimes I have had to use an impact tool to shock the screw loose, what you might try is to tighten the chuck more and then remove. there is no locking mechanism that I know about. also I would recommend going to Dewaltservicenet.com and downloading a manual/breakdown for this before starting.
May 06, 2010 | Dewalt DW999K 7/8" Cordless SDS Rotary...
Sep 08, 2009 | Drills
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
Apr 27, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
87 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
