Can not get my lines and ringer back on Meridian phone system after power went out?
  • 113 Answers
There could be a serious hardware fault but one thing to try is to remove and reseat any cards in the main switch (with the power off) and then switch everything back on.
Posted on May 23, 2011
Testimonial: "I will try it...thanks. "
  • kerri585 Jun 13, 2011
    having same problem!! we have to keep switching off and on, works ok then but looses items stored in memory.
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Meridian M8X24-DS System Problem - All handsets are blinking on all lines
Sounds like a defective software cartridge
try a swap and see if flashing stops
Nov 26, 2007 | NorStar Meridian M7310 Phone
Meridian M3820 - why is display not working
Try another 4 wire phone cord from the wall jack to the phone it is possible that you have a bad cord. These phones will only work with a Meridian System .2 wires are line ,the other 2 wires are power to the phone. If you have another phone try plugging it into the same wall jack to check the jack/line itself. Anything else would be a defective phone/ lcd ( note you can have dial tone without display, but the unit will only access one line.
Feb 19, 2015 | Nortel Meridian M3820 Corded Phone
Loud extension ringer used with Norstar Meridian phones will not ring. Any ideas why?
Most external loud ringers are analog and your phone is digital. You would also need a digital to analog converter and use an additional digital extension to make it work.
Oct 11, 2012 | NorStar Meridian 9516 Corded Phone
Norstar Meridian how to turn on the ringer
From the following web site:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Jun 15, 2012 | NorStar Meridian M7310 Phone
I have a Nortel Telecom Meridian phone at work. I often get unsolicited calls on my work phone and I just want to ignore them instead of answering them. How do I mute the ringer on my Meridian phone. It...
You can use the do not disturb function on your set. When used it will stop all ringing on your set(both line ring and intercom ring). To turn on DND, press feature 85, to turn the DND back off press feature #85.
Sep 10, 2010 | Nortel Meridian M7208 Corded Phone
There is terrible static on all lines and the phone company states that it is our phone system. We have the Northstar Meridian M7324.
It sounds like a reboot of your system may be in order, When ever you have a system wide problem of this scope the main box on your wall is having trouble. power it down and power back up, this should fix it.
Dan
Nov 02, 2009 | NorStar Meridian M2616 Phone
We lost power and when our Meridian M8X24 phone system with T7316E phones came back up we only have access to 2 lines. How do we gain access to the other lines again.
Sounds like your norstar system needs to be reprogrammed because norstar defaults back to only 2 lines when the inturnal battery fails.If the inturnal battery has failed and you reprogram this phone system and you have another power fail you will have to have you system reprogrammed again.Time for new system.
Sep 30, 2009 | NorStar T7316E Corded Phone
Meridian M7208 Phone-Only 2 lines are working
Sounds like it might be a telco problem. Do lines 3 ,4 work on the other phones?
Switch lines 1 and 3 to see if the problem changes.
Apr 22, 2009 | Nortel Meridian M7208 Corded Phone
3rd line - no ring tone on one of a 3 set phone system
Yes, as you noticed FEATURE *6 only changes the ring tone on the set...
You have to go into system programming to make this change...
-> First you need to know the extension on the set, you can find this by doing FEATURE *0 and press the Intercom button.
-> Get into programming and you'll see TERMINALS&SETS and enter
-> type in extension that is giving you problems
-> hit next till you see LINE ACCESS and enter
-> the you'll see LINE ASSIGNMENT and enter
-> type in the line 003
-> and press change to APPR&RING
-> hit next and RLS to back out of programming
Mar 04, 2009 | NorStar Meridian M7310 Phone
142 people viewed this question
jasbo
jasbo
