Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error MP830 6A00
I have error 6A00, but the printer cartridge won't move to the center so that I can tap the sponge down. Any suggestions on how to get it to move?
  • 4,041 Answers
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Canon mp600 showing error code 6A00
6A00 Is the code for a paper path feed error. this is sometimes caused by the purge unit becoming clogged with debris. The purge unit sits underneath the cartridge print head and is designed to keep the ink flowing and clear. Turn the printer on, lift the lid so the cartridges move to the center and turn off. Look where the cartridges normally sit and you will see a sponge housed in a plastic frame. Move this frame back and forward, remove the cartridges and replace them, then turn the printer back on.
If this does not solve the problem then unfortunately a replacement printer of a service call to canon is un-avoidable.
I hope this helps Regards GM
Apr 22, 2011 | Canon imageCLASS MF7480 Laser Printer
PIXMA MP830 All In One machine will not operate error code 6A00
Do you have a led error code or error on the lcd display ?
Aug 07, 2008 | Office Equipment & Supplies
I have a Canon PIXMA MX860 and have error 6a80. i have shut off and on twice no paper jam. totally stuck
6A80 is a purge unit error, the purge unit is the cleaning assembly on the right where the printhead parks when shut down. If you can move the carriage out of the corner, use a flashlight and see if there are paper scraps or the like keeping the purge assembly from moving freely.
Oct 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon i850, service error 6800
This error indicated that the internal printer counter for the waste ink sponge has reached its threshold. You should be able to reset this counter once without cleaning the sponge.
Do this:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
now try press resume button 4 times..after that press the power button
This should clear your error and let you resume printing. If you start getting ink smudges on the paper you will have to disassemble the printer and clean the waste toner sponge.
Jun 17, 2008 | Canon i850 InkJet Photo Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
CANON MP830 PRINTER ERROR CODE 6A00
6A00 is a purge unit fault, if you have have a years canon warrenty i would call them and get a engineer out to investergate the fault, If not strip machine and and see if the purge unit is moving back and forward. it could be that the carriage unit is stuck on the purge and the carriage unit cant move.
Hope this helps
Mar 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All in One - A600 error
Here’s what I found.
There is a sponge to the right as stated but right next to that is a white plastic arm assembly with a spring attached to it.
It was the white plastic assembly arm that was stuck and not fully retracted. I tried to move it back and forth and then (pingk) it fully retracted. I powered on the printer leaving the ink caddy to the left and as it was cycling I could see the plastic arm was covered with dried ink. I powered it off and moved the ink caddie to the left again and powered it on again. As it cycled I pulled the power plug leaving the assembly fully exposed. Grabbed some paper towel and put some alcohol on it and cleaned the dried ink off as best I could. I left the caddie to the left as I powered it up to see the assembly work
The printer is working again
Jan 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
154 people viewed this question
old marine
old marine
