Question about Dryers
I have a frigidaire affinity dryer model number aeq6000ces2. My problem is that I turn it on and it will run for about 10 mins of whatever cycle I put it on then it stops and the drying, door locked and extended tumble lights start blinking. I have to cancel the setting and start over and it will do it again. I have spent hours on line looking for the reason but can not seem to find anything. Hope you can help.
4 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
SOURCE: iDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Posted on Oct 05, 2011
oldTech2332
  • 2341 Answers
SOURCE: how to replace the heating element in a
Hello,This youtube video will show ya how to replace the heat element on your dryer.http://www.youtube.com/watch?v=JwMyoSa9ebw
GENE
Posted on Oct 21, 2011
E 64 code on a Frigidaire affinity dryer, but still getting heat. What could be the problem?
that has three sets of coils in it,one of them is bad this is most likely why you still have heat,i've seen it a few times,change out the heater box,go here and look at the last picture,you'll see the three sets of coils one of them is broken,just order your heater box for your model number off of your dryer.change out the heater box
https://www.appliancezone.net/134792700-frigidaire-dryer-heating-element-replacement/?gclid=Cj0KCQiAvrfSBRC2ARIsAFumcm_UzfGwntvtSVc9IDruzrS145S-0pcaF2W7iBwEOgT2y1r4boAgEPAaAoi4EALw_wcB
Jan 04, 2018 | Frigidaire Dryers
I have a Frigidaire Affinity electric dryer Model # FAQE7001LWO. . The cycle will start for about 5-7 mins once started and then it shuts off and all lights on the unit start blinking. Please Help!
Google your model number and how to retrieve the error codes. It sounds like either the heating coil or control board is bad. I have a different model that does the very same thing...they run until the cycle tried to turn the heat on then it causes an error. In my case it is the control panel and I decided since mine is old and we are a family 6 (lots of use in it) not to repair it.
Aug 04, 2016 | Frigidaire Dryers
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Have a affinity front load dryer that comes on runs five min then shuts off and all three lights by the start button come on and flash wont heat up
Hi Friend, this is Z. I appreciate your inquiry!
I interpret that you are having trouble with your Frigidaire dryer (FASE7073NW) not starting. Let's try resetting your dryer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your dryer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dryer to determine the root cause to reduce the risk of unnecessary parts. Best regards!
Aug 21, 2014 | Frigidaire Affinity FASE7073NW 27"...
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to replace the heating element in a AEQ6000CES2 frigidaire affinity dryer
GENE
Oct 21, 2011 | Frigidaire AEQ6000ES Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
