Question about Garden
I bought a testmark power washer 1500psi, model f2482. I need a new wand attachment for it, but can't seem to find where to buy or order it. :(
If you can send me pictures of the end of the wand that goes in the gun so i can see the style of connection they used then i can refer you to the correct part.
tech-support@pwpump.com
Posted on Aug 05, 2011
Mccullough FHH18A - Looking for connector adapter/ size ?
Why not just purchase a new hose assembly?
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 03, 2014 | McCulloch FHH18A Electric Pressure Washer
O Ring in pressure washer MOdel FH 140 a Keep blowing out In the wand handle need to order parts. Thanks
These are generally the same sizes for most pressure washers, except for small light duty ones. You can generally buy a set for around $6 try a pressure washer store or Home depot or Northern
Jun 09, 2011 | Garden
Don't know how to get detergent into the ultimate x pressure washer (1500psi)
To the right of the Brass fitting where your garden hose attaches there is a small round plastic cover piece, pull on that and it will pull out a clear tube with it which goes into any container containing your detergent, it will pull the detergent as you use the pressure washer. Push the tube back in after you are done using it. You can also buy a replacement detergent bottle for other pressure washers if you wanted to.
Jun 05, 2011 | Garden
Cannot attach wand after attaching the detergent holder
put the detergent holder on the end of the wand handle.take off the first section,and put bottle into that hole.my Nilfisk waterblaster is the same
Jul 05, 2010 | McCulloch FH140A Electric Pressure Washer
Need Hoover cannister vacuum floor brush & filter bags
Hello, if you GOOgle Hoover you will be able to find your nearest Hoover center, they will then be able to help you with parts and bags. We did this last year and it was emensely helpful. Hope this helps.
Nov 04, 2009 | Vacuums
How to repair a hole in the wand tubing for pressure washer
my Honda ic2 ran greet, then all of a sudden it started to slowly shutting down,
i restarted it. and it ran for about 5 min and shut down. i did this 3thee to four times do i need a gas additive or what
Apr 27, 2009 | Garden
Need parts for Wand
yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Feb 02, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
I have a karcher 411 A jet washer, there doesn't seem to be enough pressure to do the job. I have bought a new wand but it doesn't seem to make any difference, any ideas, what am I doing wrong
Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
Aug 31, 2008 | Washing Machines
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
