Question about Dymo LetraTag QX50 Thermal Label Printer
Try to print, get Error 1 - Dymo LetraTag QX50 Thermal Label Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Tape jam or battery low. Please clean the printer and/or exchange the batteries.
Posted on Dec 16, 2013
E07, e08, e02, e15 error in canon mp258, pl. give meaning of error & solution
Canon Pixma Mp258 Error Code and Possible Solution
P02 (Carriage error)
1.Make sure no foreign material stuck to the print head railway.
2.Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.P03 (Line feed error): an error in transmission line entering the line feed (LF) is a signal telling the printer to move to another line or a whole new line that would not otherwise have reached the end of the line.
1.Check wire print head position (timing **** disk film) on the side of the machine.
2.Check PCB logic board.
P05 (ASF sensor error) sensor for paper feed error.
1.Try to replace the following:
•ASF / PE sensor unit.
•Drive unit.
•PCB logic board.
P06 (Internal temperature error): caused by abnormal heat inside the printer.
P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full
1.Replace the wastepad inside the printer or install waste ink bin outside the printer
2.then Reset counter protection.
P08 (Print head temperature rise error): caused by thermal print head temperature exceeds a threshold.
1.Replace the new cartridge print head and / or change a new logic board.
P09 (EEPROM error): caused by corrupted or defective EEPROM chips of the printer.
1.Replace the logic board.
P15 (USB VBUS over current): caused by too much current, try removing the USB cable and then plugin again, if solve the error, try to replace with a new USB cable. If the error still exist replace the logic board.
P20 (Other hardware error): The failure of other hardware.
1.Try to replace the logic board.
P22 (Scanner error): a scanner malfunction.
1.try to change the scanner unit or change a the logic board.
E13 or E16: Ink has run out
1.Pressing the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
E04, E05, E14 or E15: Cartridge may not be installed properly
1.Reinstall the ink cartridge.
Jun 15, 2011 | Office Equipment & Supplies
Whenever i try to print a pdf file longer than one page from adobe reader, my e-studio4511 will only print the first page, followed by a second blank page, and then a final page with the following error...
Send the font information for each page in the PDF file when you print.
For Adobe Acrobat Professional 9:
1. Choose File > Print.
2. Click on Advanced.
3. Choose Postcript Options.
4. Under Font and Resource Policy, select Send for Each Page.
In Adobe Reader 9: try this 1
3. Under Font and Resource Policy, select Send for Each Page.
may or may not work try it
Hopefully this will be helpful to you all
Nov 20, 2010 | Toshiba e-STUDIO 4511 Printer
Error 5200 shows when trying to print. Not listed in the user manual.
I found a few answers http://www.uktsupport.co.uk/canon/bj/s400.htm
error 5200 indicates print head overheating. You might try printing 1/3 of document, pausing for cooling then print second 1/3, pausing for cooling then print final 1/3 as a work around.
Looks like thr repair cost is more than a brand new Multifunction printer/scanner
Aug 09, 2010 | Canon Office Equipment & Supplies
Windows 7 cannot print email. An error message comes up as follows Line 1507 Char 1 Error invalid argument Code 0 URL res/ieframe.dll/prieview.is
You didn't say what e-mail you are using but from the error message it looks like you are trying to print from within frames. Are you using the print button inside the email or the print in the browser window? Try using the print button inside the email program not "file, print" or a print button on the browser toolbar.
Jul 06, 2010 | Dell Computers & Internet
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
1 Turn the MFP off, and then turn the
MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file. If the message
appears only with a certain software
program or print job, contact the
software vendor for assistance.
4 If the message persists when using
different software programs and
attempting specific print jobs,
disconnect all of the cables that
connect the MFP to the network or a
computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory
cards. Do not remove the firmware
memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears,
reinstall each DIMM, flash-memory
card, and EIO device individually,
making sure to turn the MFP power off
and then on again as you install each
device.
10 Replace the component that caused
the error message.
11 If the error persists, replace the
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
Has system error E808, not listed in error codes in manual. What's this & how do I fix?
Hello sir; That's fuser error, try to reset hopfully can help you;
press "additioal function" "2" "8" "additional function" keys in that order,enter sssw 1, bit 3, press print change value from 0 to 1 , or from 1 to 0 then press print, should be take care of it.
Dec 05, 2009 | Canon imageCLASS MF6590 Copier
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
913 service motor error
If this is the first time you have seen this error, do the following:
  1. Power off the printer.
  2. Remove all installed paper trays.
  3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
  4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
  5. If everything is fine, reinstall the tray and power on the printer.
  6. Try printing a few print jobs.
  7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
  8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
  • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
  • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
    1. Put paper in tray 1 only.
    2. Print from tray 1.
    3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
    4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
    5. Power the printer back on.
    6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
      If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
      • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
      • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
    7. And if your getting the same error then you need to get it serviced...
Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Dymo LetraTag QX50 Thermal Label Printer Logo
29 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
